Calculating Glucose Concentration of Solution
  • Thread starter Thread starter MichaelXY
    Percent
The discussion revolves around calculating the glucose concentration in a 5% glucose solution with a total volume of 10 mL. Participants explore the implications of molarity and weight/volume percentages in the context of a homework problem and a laboratory setting.
  • Homework-related
  • One participant questions whether the glucose is assumed to be 1 molar in the context of the problem.
  • Another participant suggests using the molarity formula to calculate moles per liter, referencing an external resource for clarification.
  • A participant attempts to calculate the mass of H2O in the solution, leading to a derived mass of glucose based on their calculations.
  • There is a suggestion that the calculation should consider percent weight/volume of the solution rather than just volume of glucose solid.
  • One participant proposes that the mass of glucose in the 10 mL solution would be 0.5 grams, questioning if this aligns with the weight/volume percentage definition.
Participants express differing views on the correct approach to calculating glucose concentration, with no consensus reached on the methodology or final values.
There are unresolved assumptions regarding the definitions of molarity and weight/volume percentages, as well as the calculations presented by participants.
MichaelXY
[SOLVED] Percent of solution
Let's say we have 5% glucose of a 10 mL solution. So that would imply that .5 mL of the solution is glucose, but that does not really tell me how much glucose. Is it assumed that the glucose is 1 molar?
I ask because in one of my bio labs we did a lab where we were given exactly as stated above. Knowing the exact amount of glucose was not needed for the lab, however, I would like to understand this for future use.
Thanks for any input.
Yeah, the post above mine tells you exactly what you need to do.
Okay, let's see if I got this right. Since the solute is H2O, I assume 1 molar H2O.
Since 1 mole H2O = 18 grams/mole and I use the molarity formula to get grams.
10mL of H20 or .01L x 1 molar = .01 grams of H20.
ergo .01g H2O x 5% = 5 x 10^-4 gram glucose, or .0005 gram.
Is that correct?
Thanks in advance
yes now if only someone would help me for christ's sake...
I wish I could, but as you can see, I am not that good at chem. Thanks for the assist :)
You probably need to use units of percent weight/volume of solution. The glucose solution is not sensibly prepared as volume of glucose solid per volume of solution.
So by that you mean, Mass of solute/100 mL solution? So I think that would equate to .5 gram C6H12O6 @ 10mL Does that sound correct?
That would give you 5 percent weight per volume.
17K
16K
