Calculating Height for Shaun White's Snowboarding Trick
  • Thread starter Thread starter green123
The discussion revolves around calculating the height Shaun White needs to achieve during a snowboarding trick that lasts 3.5 seconds. The problem involves concepts from kinematics and energy conservation, particularly focusing on the relationship between velocity, acceleration, and height in the context of motion in a halfpipe.
  • Participants discuss various kinematic equations and their applicability to the problem. Questions are raised about initial and final velocities, the effects of gravity, and the relationship between the velocities at different points in the trick. There is also exploration of energy conservation principles.
Participants are actively engaging with the problem, offering insights and corrections regarding the initial conditions and the relationships between different variables. Some guidance has been provided on how to approach the calculations, but there is no consensus on the numerical values yet.
There is an emphasis on the assumption that air resistance is negligible and that energy is conserved during the trick. Participants are also navigating the implications of initial and final velocities in the context of the trick's dynamics.
green123
How much height above the half pipe does 85kg Shaun White need to complete the 3.5 second trick?
d=.5(vi+vf)t
net force= ma
pe=mgh
vf= vi+at
no
What kinematics equations do you know? What information does the problem give you, and is there anything else you know? You must try to answer the question before we can help.
You can solve for his exit-velocity using one of your listed equations and the relationship between [itex]v_f[/itex] and [itex]v_i[/itex], since acceleration and time are both known.
Then use one of the kinematic equations (perhaps one that relates distance to velocity and acceleration? :wink:) to find how high he goes.
What is the acceleration?
What pulls him back down into the halfpipe? :)
oooohhhh ookk... Thanks!
so it would be
Vf=0+9.8(3.5)
Vf=34.3
D=.5(0+34.3)3.5
D=60m
right?
so it would be
Vf=0+9.8(3.5)
Vf=34.3
D=.5(0+34.3)3.5
D=60m
right?
Almost! But not quite. His initial velocity will be the velocity he has when he leaves the halfpipe, so it will not be zero. What's the relationship between the velocity at which he leaves the halfpipe and the velocity at which he re-enters the halfpipe? (Hint: Assume air resistance is negligible and energy is conserved)
Also consider using a different kinematic equation to find the distance (we have velocity and acceleration and want to find his MAXIMUM distance).
is the initial velocity 34.3m/s?
If nothing acts on him except for gravity when he's doing his trick, what can we conclude about his velocity upon re-entering the halfpipe in terms of the velocity when he leaves the halfpipe?
that his velocity is 9.8m/s
We're not looking for a number for [itex]v_i[/itex] yet -- we'll solve for that later. We want to find a relationship between that and [itex]v_f[/itex]. Does this equation hold true:
[itex]v_f = v_i[/itex]?
Well of course not, because velocity has a direction and magnitude. The directions clearly are opposite, and what can we say about the magnitudes?
so vf =0?
I think I'm doing a bad job at explaining this, so I'll help you out. If all energy is conserved, then at the height of the exit of the halfpipe between [itex]t = 0[/itex] and [itex]t = 3.5[/itex],
[itex]\Delta E = 0[/itex]
And thus,
[itex]\Delta KE = \frac{1}{2} m(v_f^2 - v_i^2) = 0[/itex]
Which, as a result, gives us:
[itex]|v_f| = |v_i|[/itex]
The only difference is that [itex]v_i[/itex] is going the opposite direction, so:
[itex]v_f = -v_i[/itex]
Now try to solve for [itex]v_f[/itex] numerically using your kinematic equation.
ok, i think i got it, thanks for your help!
