Calculating Hollow Square Size for a Simple Lifting Machine
  • Thread starter sekedarimaji
    Square
4 replies · 2K views · last reply
sekedarimaji
I'am trying to make a simple machine which is to lift a display up and down. The construction mostly using hollow square.
so far I got the weight of the display and the support is 25 Kg and I have this kind of construction.
Line diagram of a lifting frame: a rectangular display labelled 25Kg sits on a horizontal hollow section, with vertical supports on each side carrying guide rollers, and a central screw below.
if simplified become like this
Free-body diagram of a rectangular frame with a shaded block on top labelled 245 N, a pin support at the middle of the crossbar, and roller supports at both bottom corners of the vertical posts.
which is the right moment happen in that construction?
a.
Line diagram of a simplified frame: a horizontal beam with downward green arrow labelled 245 N at its centre, a pin support under the centre, and two vertical legs ending in fixed supports at each bottom corner.
b.
Free-body diagram of a rigid frame: a horizontal beam with a pin support at its centre, two vertical legs with fixed supports at their ends, and two downward loads of 122,5 N applied at the beam's ends.
Is that necessary to calculate the moment?
how do i get the right hollow square size?
mfb said:
Assuming your frame is rigid, both diagrams are equivalent.
so calculating the moment is not necessary?
is there any formula to get the right size of hollow square?
Ask yourself what forces each tube is subject to. Perhaps start with the horizontal tube.
