Calculating i5 Using Kirchoff's Junction Rule
  • Thread starter Thread starter MarieWynn
    Junction
The discussion revolves around calculating the current i5 using Kirchhoff's junction rule in a circuit configuration. Participants are provided with specific current values and are attempting to apply the rule to find the unknown current.
  • Participants discuss the application of Kirchhoff's junction rule, questioning the impact of current direction on the calculations. Some express confusion regarding the roles of different currents at the junction and how to properly account for them.
There is an ongoing exploration of the correct application of the junction rule, with various interpretations of the current directions being discussed. Some participants have provided guidance on setting up the equations, while others reflect on their understanding of the node concept.
Participants note challenges with visualizing the circuit diagram and identifying nodes, which may affect their understanding of current relationships. There is also mention of differing current magnitudes and directions contributing to confusion.
MarieWynn
Calculate the current i5 in the configuration. Use the following data: i1=8.65 A, i2=5 A, i3=7.85 A, and i4=8.5 A.
Kirchoff's junction rule states that the sum of the currents meeting at a junction has to equal zero.
According to the junction rule, i1+i2+i4=i3+i5. When I plugged in the numbers, I got i5=14.3 A but my homework says that is wrong. Does the direction of the arrows affect the outcome or am I overthinking it at this point?
It is better to either add up the currents leaving a node, or add up the currents entering a node. I personally like to add the currents leaving a node and set that sum equal to zero. So yes, the arrow directions definitely do make a difference. Since I like to add up the currents leaving a node, I would use a + sign on all of the currents in the figure that are leaving the node, and a - sign on the currents that are entering the node. The sum of thoses currents (with either a + or - sign in front of each) has to equal zero.
\Sigma I_n = 0
So for my particular example:
Entering the node: i1, i4, and i3? i3 and i5 confuse me. When I add up the total, I get -i1+i2-i3-i4=-20. So i5 would have to be 20 for the total to equal zero. I feel like I am still missing something here.
That is all correct, IMO. So you write the equation like this:
-i1+i2-i3-i4+i5=0
And solve for i5. That gives you the answer you mention. Is it correct?
The problem with the diagram is that it is hard to see a node.
A node is basically a point in space where the different circuit elements meet.
Notice how i3 and i5 are heading to the same direction but they are different in magnitude.
This is when you know there is a node(s) between.
Thanks so much guys! 20 was correct and I understand why. :)
15K
