Calculating impact parameter
  • Thread starter Thread starter nocks
    Impact Parameter
The discussion focuses on calculating the impact parameter for plotting the trajectory of a photon near a Schwarzschild black hole. The impact parameter is described as the sideways distance at infinity, which can be defined mathematically. Participants share equations related to photon trajectories and Schwarzschild coordinates, emphasizing the complexity of the calculations involved. There is a mention of resources that provide additional assistance, including plots of trajectories for different impact parameters. The conversation highlights the challenges faced by those without a formal physics background in understanding these concepts.
nocks
I'm trying to plot the trajectory of a photon near a schwarzschild black hole. I have the equation for the trajectory but I'm stumped by the impact parameter and cannot find out how to calculate it.
\frac{d\phi}{dr} = \pm \frac{b}{r^{2}\sqrt{1 - \frac{b^{2}}{r^{2}} (1 - \frac{r_{s}}{r}})}
Welcome to PF!
Hi nocks! Welcome to PF! :wink:
From the PF Library on photon sphere …​
The usual Schwarzschild coordinates, are related to the "age", \tau, of a photon (measured as number of wavelengths, since of course the "proper time" of a photon does not change) by the equations:
\frac{dt}{d\tau}\ =\ E/(1\ -\ 2M/r)
\frac{d\phi}{d\tau}\ =\ L/r^2
\frac{dr}{d\tau}\ =\ \pm E\sqrt{1\ -\ (1\ -\ 2M/r)L^2/E^2r^2}
Does that help? :smile:
Thanks for the link but there's no mention of the impact parameter
(just got up :zzz: …)
Well, if you mean the "sideways distance at infinity", that'll be limr->∞ r sin(φ - φ),
which is … ? :smile:
Oh so the impact parameter is the distance parallel to the centre of the black hole at approach from infinty?
Now to attempt plotting the trajectory. Is the equation I mentioned above enough for this? (i should mention I am not a physicist)
You're not a physicist? Then whyever are you doing this?
You may find some assistance at http://Albert51.tripod.com/non.html" , including some plots of trajectories for different impact parameters. :smile:
Just an interest of mine. It's taking a while to get my head around the maths but I guess I'm slowly getting there.
  • · Replies 34 ·
  • · Replies 46 ·
  • · Replies 22 ·
