Calculating Initial Velocity Needed to Reach Specified Height
6 replies · 35K views · last reply
goombachu
I have a projectile that shoots straight up into the air (parallel to the y-axis). I need to calculate the initial velocity needed to reach a specific height. I am given the following:
- the y-displacement (s1) to reach
- the time (t) at which the projectile reaches the specified height
- the acceleration due to gravity (a = -9.8 m/s/s)
Additionally, after time (t), velocity should be zero, and the projectile should be at the specified height. In other words, it takes (t) seconds to reach the "apex."
Nothing given, but I suspect:
s1 = s0 + (v0 * t) + (0.5 * a * t * t)
Let's say:
- s0 = 0 meters
- s1 = 1 meters
- t = 0.25 secs
- a = -9.8 m/s/s
- v0 = ?
I thought I'd solve for v0 in the equation above. That gives:
v0 = s1 / t - (0.5 * a * t)
v0 = 1 / 0.25 - (0.5 * -9.8 * 0.25)
v0 = 4 - (-1.225)
=> v0 = 5.1225
That seems valid, but now let's say I need to update the velocity 30 times per second. This means that I am starting with an initial velocity of 5.1225 m/s, and each "tick" I need to decrement the velocity by some amount. After 0.25 seconds my velocity should tick down to zero.
I am guessing I would use (v1 = v0 + a * t) per "tick" for this, correct? Where v0 is always 5.1225 and (t) increments by (1/30) in each tick?
Let's say:
- s0 = 0 meters
- s1 = 1 meters
- t = 0.25 secs
- a = -9.8 m/s/s
- v0 = ?
v0 = 4 - (-1.225)
=> v0 = 5.1225 <-----------Error: =5.225
You can use the V = Vo -a*t (treat a as negative) relationship at each 1/30 to give you V at each point leading up to 0. You can merely note in that regard that you will be decrementing by 9.8/30 = .32667m/s for each 1/30
That is what I thought as well, but:
0.25 secs * 30 ticks per second = ~8 ticks
0.32667 m/s * 8 ticks = 2.61336 meters
So my velocity doesn't tick down to zero in the 0.25 seconds I have to get there.
That's because you didn't calculate the maximum height. You derived an equation for what the initial velocity would be if after 1/4 sec it got to height 1 meter.
To calculate initial Velocity if the max height is 1 m then you would choose V2 = 2*(9.8)*1
That means V = 4.427m/s and the time to do that is x = 1/2*9.8*t2 and the time then is .4518 s
OK maybe I should rephrase the problem then to be clear. I need to velocity to hit zero at a predetermined height (1 meter in this example), and it needs to take exactly a predetermined amount of time (.25 seconds in this example) to get to that height. A negative force (which I thought could be gravity) must act on the projectile in order to launch it at a high speed and slow it down as it gets closer to the height.
Need to figure out:
a) What velocity to launch the projectile at in order to reach a given height at a given time
b) How to decrease the velocity in each 1/30 tick in order to reach velocity = 0 at a given time
The method you suggest looks like it doesn't get me to the predetermined height in the predetermined amount of time. At first glance it would seem that I might need to change the acceleration in order to do that?
Need to figure out:
Looks like that's all that's left that you can change then.
On a planet far, far, away there is a boy playing with a ball ...
Right. So now i have 2 unknowns then: initial velocity and acceleration.
I don't readily see any of the standard kinematic equations that could help me find both? The only one that doesn't involve both unknown terms is d = avg_vel * t, but that doesn't really give me an initial "launch" velocity does it?
