Calculating Lorentz Force: Is the Formula the Answer?
2 replies · 2K views
tsang
Can anybody help me that how to work out the direction of Lorentz Force? Should I work out from the formula? Thanks.
See thumbnail photo of an electron beam (~ 300 volts) being bent into a circle (~ 1 cm diameter arc) by a magnetic field (Helmholz coil). This is an undergraduate physics lab experiment for measuring the electron charge to mass ratio.
Bob S
The equation gives the directions.
[tex]\mathbf{F} = q \left( \mathbf{E} + \mathbf{v}\times\mathbf{B} \right)[/tex]
For a positive test charge there is an electric force in the direction of the applied electric field. There is also a force in the direction of the curl of the charge's velocity and the applied magnetic field. Together these define the Lorentz force.
