Calculating Magnitude Difference: Is it Right?
The calculation of magnitude difference using the formula -2.5log(11347/10606) yields a result of -0.073. The discussion highlights the importance of correcting total-count values for background levels, which are indicated as 100, rather than being treated as uncertainty. To calculate uncertainty for the difference, participants suggest using the standard deviation from a Poisson distribution and applying error propagation rules. Clarification on the origin of the formula 'SE=𝜎/sqrt(2n-2)' is also necessary for accurate calculations.
  • Understanding of logarithmic calculations in astronomy
  • Familiarity with Poisson distribution and its standard deviation
  • Knowledge of error propagation techniques
  • Basic concepts of background noise in measurements
  • Research the application of Poisson distribution in astronomical measurements
  • Study error propagation methods in statistical analysis
  • Learn how to correct for background noise in data collection
  • Explore the derivation and application of the formula 'SE=𝜎/sqrt(2n-2)' in statistical contexts
Astronomers, statisticians, and researchers involved in data analysis and measurement correction in scientific experiments.
ChrisWM
We make two observations of the same star on different nights. In the first observation, the integrated flux value is 11,347 counts and in the second observation the integrated flux is 10,606 counts. Assume that the background level(dark & bias)is 100 counts for each observation. Also assume one count per photon(i.e. QE=100% and gain = 1).
a. Compute the difference in the star’s brightness and the uncertainty in that difference.
M=-2.5log(f1/f2) SE=𝜎/sqrt(2n-2)
I have found the difference in the magnitude from the counts to be -.073 using -2.5log(11347/10606) but I m unsure if this is right or how to calculate the uncertainty
It looks like the number 100 is a given standard error(uncertainty) for a single measurement. Perhaps you could use that to find the uncertainty for the difference.
I think the '100' is the background level, not an uncertainty; it is basically the reading you'd still get with no star in view (e.g. like background level when measuring ionising radiation).
@ChrisWM first needs to correct the given total-count values to allow for this background.
It's not clear where 'SE=𝜎/sqrt(2n-2)' comes from. The standard deviation for each total-count measurement can be found by using the standard deviation for aPoisson distrubution.
Then the final answer can be found using the rules for error propagation.
  • · Replies 17 ·
