Calculating max weight object supports without counterweigh
10 replies · 3K views · last reply
James O'Neill
In tower cranes counterweights are placed on the counter jib to prevent the crane from falling over. Whereas on mobile cranes the counterweights are placed directly behind the cabin.
The crane in itself also acts as some counterweight.
My question to you is:
How much weight can an object support on one side, without using counterweights, before falling over?
E.G. a 40 cm arm with an 8 Kg weight is added to a 20 Kg box. Will the box support the weight without tipping to the weighted side?
Depends on the size of the box. You want to make a balance about the potential tipping axis.
On the left you have 20 kg x half the length of the box
On the right you have 8 kg x 0.4 m
Half the length applies if the box has uniform mass density (horizontal distance between center of mass and tipping axis -- the lower right)
Make a force diagram to see.
I have made a sketch as example.
Side-view diagram of a tall rectangular block labelled 25 cm wide and 50 cm high, marked 20 Kg, with a horizontal arm extending right 40 cm to a black square block marked 8 Kg.
So on the lefet you have 20 x 0.125 kg m and on the right 8 x 0.4 kg m. Sum is 0.7 kg m to the right will keel it over !
I'm having some trouble seeing how you got 0.7 kg m at the end??
Also just curious, does three dimensional properties (l x h x w) have any effect on this?
20 x 0.125 kg m minus 8 x 0.4 kg m is minus 0.7 kg m.
Of course. If you lay the box on its side, you get 20 x 0.25 kg m minus 8 x 0.4 kg m is plus 1.8 kg m and the contraption will stay put.
Ohhh... I thought since you said sum in your second message I had to add the two together.
This makes sense.
If the 8kg weight was directly against the side of the box, it would also stay up, right? (20 x 0.125 kg m) - (8 x 0.125 kg m) = 1.5 kg m.
Yes, sum They are vectors and try to rotate in opposite directions, so one has a minus sign. Analogous to pulling to the left and pulling to the right.
Nice try, but that case the 8 kg would try to rotate to the right with 8 kg times the horizontal distance of the center of mass of the 8 kg weight to the potential tipping point. Which is not the .125 m if it's an iron weight
So let's make the weight 10 cm long.
(20 x 0.05 kg m) - (8 x 0.05 kg m) = 0.6 kg m. Is it right this time?
Can you then adjust this formula to calculate counterweight needed?
So let's make the weight 10 cm long. (20 x 0.125 kg m) - (8 x 0.1 kg m) = 1.7 kg m. Is it right this time?
It would be (20 x 0.125 kg m) - (8 x 0.05 kg m)
See it as a see-saw or a weighing scale with uneven arms. As long as m1x1 - m2x2 > 0 it won't topple over point P
Diagram of a tall block on a fulcrum p with mass m1 at horizontal distance x1 from its pivot, and mass m2 on an arm extending right at distance x2, both with downward weight arrows.
Thank you for your help. I grasp it now.
(20 x 0.125 ) -(8 x 0.05) = 2.1 kg m. Won't topple over.
