Calculating Maximum Kinetic Energy in a Flywheel
  • Thread starter Thread starter makeAwish
    Rotational
6 replies · 5K views
makeAwish
Energy is to be stored in a flywheel in the shape of a uniform solid disk with a radius of = 1.30m and a mass of 66.0kg . To prevent structural failure of the flywheel, the maximum allowed radial acceleration of a point on its rim is 3600m/s² .
What is the maximum kinetic energy that can be stored in the flywheel?
The attempt at a solution
I took I = 3/2MR² (at rim)
where R = 2.6m
Then K = 1/2 * I * ω², where ω² = a/R
so K = (1/2)(3/2)(66kg)(2.6m)²(3600/2.6) = 463320J
which is wrong..
The ans is 7.72x10^4 J
can someone pls tell me where i gone wrong?
Thanks!
Radial acceleration = [tex]m r^2 \omega[/tex]
Find out [tex]\omega[/tex]
Calc. K.E using the equation [tex]\frac{1}{2} I \omega^2[/tex]..
where R = 2.6m
Not quite. The equation is correct, but ω = v/r = 3600/1.3
As noted by rl.bhat a uniform disk has a moment of inertia of of 1/2mr².
The Moment of Inertia isn't always 1/2 mr^2, is it?
It does depend upon the axis chosen, with M.I. of the new axis found out using parallel and perpendicular axis theorems.
