Calculating Maximum Stress for Flat Bar w/Circular Hole
The discussion revolves around calculating the maximum stress for a flat bar with a circular hole under a specified load. Participants are exploring the concepts of stress concentration factors (SCF) and nominal stress, as well as the implications of geometry on these calculations. The context includes theoretical and mathematical reasoning related to material stress analysis.
  • One participant calculates the nominal stress for a plate without a hole to be 50 MPa using the formula P/A.
  • Another participant expresses difficulty in finding the correct area for the plate with a hole.
  • Several participants discuss how to determine the stress concentration factor (SCF) using a graph that relates the diameter-to-width ratio (d/b) to the SCF.
  • A participant calculates the d/b ratio as 0.5 and estimates the SCF to be 2.2 based on the graph.
  • There is a correction regarding the use of the net section area at the hole for calculating the SCF, indicating that previous calculations may not be accurate.
  • One participant claims to have found the maximum stress near the hole to be 110 MPa, calculated as 2.2 times the nominal stress of 50 MPa.
Participants generally agree on the method to find the SCF and the calculations involved, but there is disagreement regarding the correct area to use for calculating the SCF, leading to uncertainty about the accuracy of the maximum stress calculation.
Participants have not resolved the implications of using different areas (net vs. gross) for calculating SCF, which may affect the accuracy of the maximum stress derived from the SCF. There are also unresolved assumptions regarding the validity of the graph referenced for SCF determination.
qwerty0123
trying yo figure this out:
the graph of stress concentration factor K for flat bars with a circular hole geometries are shown in the diagram link below. a load of 50kN is applied to the plate. the width of the plate b=100mm with a thickness of t=10mm
find the maximum stress for the following:
1. plate without hole
2. plate with hole (diameter 50mm)
3. how much is SCF? well k=nominal stress / maximum stress but I am not sure how to get the maximum stress, is it s chart or the graph below?
http://imageshack.us/photo/my-images/15/scfvk.jpg/
this is what i have done so:
stress=P/A
p=50X10^3
A=(b-d)h = 50mm x 10mm = 500mmsquared = 0.0005m squared??
so nominal stress is = 50x10^3/0.0005 = 6000?
ive found the stress for the plate without the hole to be:
P/A
P/bt= 50000/0.001
50MPa
cant do the second bit though
cant find the correct area either
Pick out the stress concentration factor based on the given dimensions and solve for the max stress near the hole using your formula.
how do i do that?
qwerty0123 said:
how do i do that?
Stress concentration factors are derived from the Theory of Elasticity. In this example, the stress concentration factor is plotted on the y-axis and the d/b ratio is plotted on the x axis. Find the correct value of d/b on the x axis, and move up vertically until you hit the curve (hint, the SCF is somewhere in between 3 and 2.5). Once you determine the SCF, then use the formula given in the chart to calculate the max stress near the hole. Note that the reference (nominal) stress is calculated based on the cross section area of the plate minus the cross section area of the hole. You would get different SCF factors if you use the stress on the plate without the hole as your reference stress. I assume the graph given is given correctly.
i've got d/b to be 0.5 since d=50 and b=100 d/b=50/100 = 0.5
using the graph i get 2.2?
Oh yeah that's about right I gave a bad hint because I wasn't looking at the graph and going from my incorrect memory of it from an earlier viewing, Sorry. So now that the SCF is 2.2, calculate the max stress near the hole using the formula given on the chart.
haha that's ok...ive managed to get the maximum stress as 110MPa
since 2.2x50MPa = 110 000 000
thats part 2 done but what about part 3 the SCF?
But the SCF factor is based on the nominal stress using the net section area at the hole, not the gross section area. Your answer is not correct.
You just told me that the SCF is 2.2!
35K
