Calculating measurement uncertainty
Determining measurement uncertainty involves understanding whether it is a statistical measure or a maximum error bound. For statistical measures, uncertainty is often expressed in terms of standard deviation or standard error, which indicates the probability of errors falling within a certain range. In contrast, maximum error bounds are calculated based on the highest expected error, leading to a straightforward ± value. The number of decimal places in the uncertainty should match the measurement's precision. Ultimately, the choice between different uncertainty values depends on the context of the measurement and the nature of the errors involved.
AbsoluteZer0
Hi,
I've been studying uncertainty in measurement. I'm not sure how to decide if the uncertainty of a given measurement should be ±.01 or ±.02 or ±.03, and so forth. I understand that the number of decimal places in the uncertainty calculation should correspond to the number of decimal places in the measurement, but I am not sure as to when I should decide whether the uncertainty contains a 1, 2, 3, and so forth.
Thanks,
Mathematics news on Phys.org
Hey AbsoluteZer0.
If it's a statistical measure of error, this usually corresponds to some kind of standard deviation or standard error (both refer to different things: one being a population measure typically and the other being a sample statistic typically), but if it's not statistical it may correspond a maximum error bound.
If it's the latter then typically you will figure out what the maximum error is and use that since all values will lie in-between +- that value.
If it's statistical then this is different because what happens usually in this case is that you have +- so many sigma contains a probabilistic proportion that a fraction of the errors according to some constraint will fall in that region and the rest won't.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 18 ·
  • · Replies 21 ·
