Calculating Minimum Force for Turning a Barrel over a Step
  • Thread starter Thread starter tgpnlyt7095
    Forces Turning
32 replies · 10K views · last reply
tgpnlyt7095
Hand-drawn diagram of a circular barrel against a step, with a horizontal arrow F pushing at its right side, a dimension of 0.3 m from the barrel's center to the arrow, and a vertical dimension of 0.2 m marked at the step height.
Find the smallest horizontal force required to push the barrel over the step.
n/a
By the principle of moments,
F x 0.2 = 1500 x 0.5 .
Thus, F = 3750N.
I think that there's a smaller force, right??
What's the height of the force F? Where's your pivot?
the height is 0.2 + 0.5 = 0.7m.
The pivot , i suppose is the edge of the step ??
Your diagram shows the force level with the center of the barrel. I guess that's wrong? And the height of the step is labeled as 0.2, but it's drawn as being at the height of the force.
What's the height of the step? Where is the force applied? At h = .5? or .7?
Right. So what's the moment arm (distance) for computing the torque due to F?
What's the height of the step? Where is the force applied? At h = .5? or .7?Right. So what's the moment arm (distance) for computing the torque due to F?
My apologies. the height of the step is 0.2m . And 0.5 represents the radius of the circle.
The force is applied at the height of 0.7m
Excellent. So what's the torque due to that force about the pivot? And what's the torque due to the weight of the barrel?
It should be, F x D = 1500N x 0.7m = 1050Nm
What's the value of D? I assume the barrel weighs 1500 N? How far is the center of the barrel from the edge of the step?
Distance of Barrel from the centre to the edge of the step
= 0.5m
so is it F x D = 1500N x 0.5m
= 750Nm ??
the weight (1500N) is not perpendicular to the distance so it's not 1500N x 0.5m.
you need to use some trigo here, i think (unless there's a shortcut method).
arkofnoah said:
the weight (1500N) is not perpendicular to the distance so you can't do 1500N x 0.5m
But i thought its a circle ??
I think i got it.
F x D , = 1500N x ( 0.5m - 0.2m )
= 450Nm
= 0.5m
No. That's the radius of the barrel. (Use a bit of trig/geometry.)
= 750Nm ??
Again, D is the distance between the line of the applied force F and the pivot. So what is D?
0.5m - 0.2m = 0.3m
actually the distance of Barrel from the centre to the edge of the step is the radius of the circle :-p
LOL... yeah, I should have said "What is the horizontal distance from barrel center to the edge of the step". :redface:
tgpnlyt7095 said:
0.5m - 0.2m = 0.3m
What's the height of F? What's the height of the step? The vertical distance between them is D.
Okay, so the torque is 1500 x 0.3 = 450N ?
arkofnoah said:
okay... you need to find the perpendicular component of both forces (in green).
http://img843.imageshack.us/img843/5620/screenshot20100806at013.png
and you'd probably need trigo to do that (though I suspect there's some form of symmetry here. hmmm).
Gosh... I appreciate the opportunity u guys had given me to be involved in the thinking procedures of solving this question but i have not learned trigo in my elementary mathematics ... is there an alternative ?
trigo is the surefire and easiest way to do this. i think you might somewhat bypass using trigo by falling back on geometry (from the look of that diagram) but it's probably very clumsy and non-intuitive, if it's possible at all.
Can i take a look at the solution / steps involved??
arkofnoah said:
something like this using similar triangles:
http://img689.imageshack.us/img689/4745/screenshot20100806at025.png
just a rough sketch i don't know if i got the alternate angles right so do check it again. you should pick up trigo asap because the above method is rather crude.
So, based on this diagram, what am i supposed to find ?
Can u show me the trigo way of doing it ?
based on similar triangles (you learned this before right), find W' (the green one). Assuming that the net moment is zero when F is just enough to balance W, W' = F'. From F' get F using similar triangles again.
What about the trigo way ??
OH! actually i just realized we don't need to do all that.
F x 0.3 = 1500 x 0.4
That's it (the sides of the triangle I've drawn is found using pythagoras' theorem). Sorry for complicating the matter :-p
