Calculating Objective Lens Focal Length for Compound Microscope
  • Thread starter thundercats
    Microscope
7 replies · 9K views · last reply
thundercats
The barrel of a compound microscope is 14.8 cm in length. The specimen will be mounted 1.03 cm from the objective, and the eyepiece has a 4.92 cm focal length. Determine the focal length of the objective lens
(1/Do)+(1/Di)= (1/f)
what did was i added 1.03 with 13.8 to get the distance of object from the eye piece. then i plugged the numbers in the equation ( with the focal point of the eye piece) to get the distance of the image from the eyepiece. then i used the image distance i got and subtracted it from the 14.8 to get the image distance from the objective lense to the image and i plugged into solve for f. but my answer comes down to be .99 cm which is wrong
thundercats said:
… what did was i added 1.03 with 13.8 to get the distance of object from the eye piece. then i plugged the numbers in the equation ( with the focal point of the eye piece) to get the distance of the image from the eyepiece. then i used the image distance i got and subtracted it from the 14.8 to get the image distance from the objective lense to the image and i plugged into solve for f. but my answer comes down to be .99 cm which is wrong
Hi thundercats! :smile:
I can't really tell what you did without seeing your equations …
but you don't seem to have used the position of the intermediate image. :confused:
i think i see what you are saying but now I am more confused. this is how i have started to set it up again. what i don't seem to understand is how to use the 14.8 which is the length of the barrel. I am not sure if I am suppose to use it to find Df (distance of final image)or something
(1/1.03)+(1/Di1)=(1/F1)
(1/Di1)+(1/Df)=(1/4.92)
thundercats said:
… what i don't seem to understand is how to use the 14.8 which is the length of the barrel.
14.8 is the sum of two of the distances. :smile:
hmm. by saying its the sum of the two distances I am assuming ur saying that its the distance between the two lenses of the compund microscope so i guess i can plug that into my 2nd equation making it look like this
(1/Di1)+(1/14.8-Di1)=(1/4.92)
am i close :D. by the way how do u know to reply back to my posts i was just wondering :D
there is still something wrong with it i can't figure out what i was thinking maybe the sign has to be negetive since the final image is going to be to the left of the second lens meaning
(1/Di1)-(1/14.8-Di)=(1/4.92)
Just got up … :zzz:
That's right. :smile:
It should work … show us what you got.
(everyone gets email notification of any thread they've posted in :wink:)
