Calculating Orbits: Finding Satellite Distance from Earth
This discussion focuses on calculating satellite distances from Earth using the polar coordinate formula r=p/(1-e*cos(theta)), where p is set to 1200 km and e represents eccentricity values of 0, 0.25, 0.5, 0.75, and 1. A Fortran program is being developed to compute r based on user inputs for e and theta. Participants also discuss using XMGRACE for plotting results and writing output to .dat files in Fortran.
  • Understanding of polar coordinates in orbital mechanics
  • Basic knowledge of Fortran programming
  • Familiarity with eccentricity in orbital calculations
  • Experience with data visualization tools like XMGRACE
  • Learn how to implement the Fortran program for calculating satellite distances
  • Explore the use of XMGRACE for plotting data from Fortran outputs
  • Research methods for exporting data to .dat files in Fortran
  • Investigate techniques for comparing floating point operations in different Fortran programs
Aerospace engineers, Fortran programmers, and researchers in orbital mechanics will benefit from this discussion, particularly those looking to calculate and visualize satellite orbits.
kathrynag
I am doing a problem with calculating orbits.
The orbit can be expressed in polar coordinates as r=p/(1-ecos(theta)) where r and theta are the distance and angle of the satellite from the center of the earth, p is a paremter where p=1200 km, and e is a parameter representing eccentricity.
I'm supposed to write a program to calculate the distance of the satellite from the Earth as a function of theta if the satellite has an eccentrity of 0, .25, .5, .75, and 1.
Write the program to input values of e and theta. Here is what I have done:
program calculating_orbits
implicit none
real :: r !distance of the satellite from the center of the earth
real :: theta !angle of the satellite from the center of the earth
real, parameter :: p=1200 !parameter specifying the size of the orbit
real :: e !parameter specifying the eccentricity of the orbit
write (*,*) 'This program accepts inputs of theta and e and outputs the
+ value of r=p/(1-e*cos(theta)).'
write (*,*) 'This program will run until a number not in the domain
+ is inputted.'
do
write (*,*) 'Please input a real number.'
read (*,*) e
read (*,*) theta
Now I get stuck. Any hints?
Technology news on Phys.org
can you try to write this in fortran and print r as your result?
Few questions in fortran :)
1. Which is the best plotting tool in fortran
2. How to get out put in form of .dat files in fortran
3. Can anyone post a code for calculating floating point operations and finally plotting it..I read so many papers i never able to understand how they plot those
If you're using *NIX, you can use XMGRACE. Typically I just write a file which can be easily read into Excel.
You can write in any form you want. I don't understand.
Code:
OPEN(11,file='output_file.dat',form='formatted')
DO i=1,10
  x = REAL(i)
  y = x**2
  WRITE(11,*) x,y
END DO
CLOSE(11)
What about calculating floating point operation, suppose i have a mac and i am running a program then how to compare two programs ..how to plot graphs between floating point operations ...between these two programs
  • · Replies 25 ·
  • · Replies 39 ·
