How Do You Calculate Photon Flux from Apparent Magnitude?
  • Thread starter Thread starter roman93
To calculate the photon flux from an object with an apparent magnitude of 31, the flux was determined to be approximately 1.02 x 10^-20 W/m². The typical optical wavelength used for calculations was chosen as 570 nm, leading to an energy per photon of about 3.49 x 10^-19 J. Dividing the calculated flux by the energy per photon resulted in a photon count of approximately 0.03 photons per unit time per unit area, indicating the source's faintness. The discussion highlighted the importance of accurately calculating flux and energy to understand photon flux. The calculations confirmed the extremely low photon count, consistent with the object's faintness.
roman93
The faintest objects that have been detected at optical wavelengths with the Hubble
Space Telescope have apparent magnitudes m  31. Calculate the flux from
an object of this magnitude, and, assuming that each photon has a typical optical
wavelength, convert your result into the number of photons per unit time per unit
area at Earth (this is the so-called photon flux).
[The Sun has apparent magnitude m = -26.8, the flux from the Sun is 1350Wm^-2]
m_2 - m_1 = 2.5log( f_1/f_2) log with base 10 here
E = hf, λ = c/f
well I worked out the flux of the object to be 1.02*10^-20 Wm^-2. (I'm pretty sure this is right) however I am not sure what the typical optical wavelength is or how to go about working out the "Photon Flux".
I thought if I could work out the energy of a photon with typical wavelength, I can then divide the calculated flux by energy of photon which will give me the number of photons...
I am not sure how I work out the number of photons per unit time though =/
Typical optical wavelength would be those of visible light.
typical optical wavelength just means a wavelength somewhere in the visible spectrum
since the visible spectrum goes from 390nm to 750nm, looks like 570nm would be a good choice, it's right in the middle
and so using that, you should be able to figure out the typical energy per photon
if you have
\frac{energy}{photon}
and
\frac{energy}{seconds*area}
then how would you get
\frac{photon}{seconds*area}
if you have
and
guess I just divide one by the other. How do I work out the energy given the flux? (The total energy would be luminosity right?) if so the formula f = L / 4(pi)d^2 is the diameter the object receiving or the one emitting?
Energy of what, and, more importantly, what for?
flux *is* energy
watts per unit area is energy per unit time per unit area
the flux tells you how much energy is moving through a surface per unit time
SHISHKABOB said:
flux *is* energy
Oh perhaps... I calculated the flux wrong then. Because using a wavelength of 570nm I get the energy per photon to be higher than the flux. so surely I can't have almost 0 photons reaching earth?
can you check that I have calculated the flux right?
m_1 = 31, m_2 = -26.8, f_1 = ? and f_2 = 1350.
31+26.8 = -2.5log(f_1 / 1350) so
10^(-57.8/2.5) = f_1/ 1350 so f_1 = 1350*10^(-57.8/2.5)
Almost is subjective. Your flux seems correct.
okay E = hc/λ. so using a wavelength of 570nm I get that E = 3.49*10^-19 J.
so the number of photons = (1.02*10^-20)/3.49*10^-19 which is 0.03...
I think somewhere I went wrong but can't figure out where?
It is indeed a very small number, that's why the source is considered very faint.
Ah okay, thank you both very much for your help!
