Calculating Power and Efficiency of a Heat Engine with 6 kg/h Gasoline Input
  • Thread starter Thread starter mado134
    Thermodynamic
The discussion revolves around calculating the power output and efficiency of a heat engine that uses gasoline as fuel. The original poster presents a scenario involving a specific fuel input rate and calorific value, along with heat rejection data.
  • The original poster attempts to convert the fuel input rate into a power output by multiplying the fuel mass flow rate by its calorific value. They also express their understanding of efficiency in terms of work done and heat rejected, but seek validation of their approach.
Participants are actively engaging with the original poster's calculations, providing feedback on the equations used for efficiency and power output. Some participants clarify the relationship between heat input and output, while others point out potential misunderstandings in the equations presented.
The original poster expresses uncertainty about their calculations and mentions a lack of preparation for the topic, which may influence their understanding of the concepts involved.
mado134
A heat Engine receives 6 kg/h gasoline which has a calorific value of 42000 kj/kg. If heat rejected from the engine is 40 kw, calculate
a- the power done by the engine
b- the engine effiecincy
-this wt i got today in my exam and unfortuntely i didnt study it well but i did the following :
1- 6 kg/h -----> 1/600 kg/s
then i multiplied it by the 42000 kj/kg
so i can get kj/s ( which is the power )
so is that correct ??
2- i said effieciency = w/Qh = 1 - Qh/Ql
and Qh = W - Ql = 42000 - 40
so is that too correct ?
* i knw i didnt study well :cry: and sorry if i posted it in a wrong section
Efficiency is 1 - Ql/Qh
thanks for quick reply
sure i knw that
but my question is : wt i wrote is right or wrong ?? bcse i got diff units and no more details
The output of the engine is Qh-Ql. Multiplying fuel rate of use by caloric content only provides Qh. You must subtract Ql from it to arrive at power output. Ql is heat rejected and it is lost.
You have the equation for efficiency wrong. You wrote
"2- i said effieciency = w/Qh = 1 - Qh/Ql "
  • · Replies 20 ·
  • · Replies 16 ·
9K
  • · Replies 23 ·
