Calculating power as a function of time
5 replies · 5K views · last reply
hk4491
A force of 5 N acts upon a body of 8 kg in the +x direction. Formulate an expression for the power generated as a function of time. The body is in the beginning at t=0 and x=0 (Sorry I'm translating this question from German, so excuse the mistakes).
Work = Force * distance
Power = ΔW/Δt
Force = mass * acceleration
Since the force of 5N is acting on the body, by Newton's third law, it is also exerting the same force, so that:
F = m * a
5 = 8*a
a=5/8 m/s^2
By integrating the acceleration twice I get the distance as a function of time:
x(t) = 5/8 t^2
Work = Force * distance = 5 * (5/8)t^2 = (25/8)t^2
P(t) = (25/8)t
Was my method correct?
x(t) = 5/8 t^2
You forgot something in doing that integration.
P(t) = (25/8)t
You have divided the total work done over the distance by the total time taken. That will give you average power, but I think it is the instantaneous power at time t that is wanted.
Thanks I realized my mistake in the integration part. That leads to x(t)= 5/16 t^2.
The body starts moving at t0=0, so at any given point of time Δt = t - t0 = t
Hence:
P= (F*d)/t
P(t) = 25/16 t
Hence:
P= (F*d)/t
P(t) = 25/16 t
No. You missed out a factor of half in your integration, so the correct expression for total work done at time t should be ##W(t) = \frac{25}{16}t^2##. This expression is not linear in t, so can you simply divide by t to find the power at time t? Shouldn't you be differentiating?
Basically, your original expression was correct - simply because your errors "cancelled out". You missed a half when integrating, then divided instead of differentiating, so you didn't include a requisite factor of 2.
Another way of arriving at the answer is to remember that the instantaneous power is equal to the force times the velocity. The velocity at time t is 5t/8.
