Calculating power as a function of time
The discussion centers on calculating power as a function of time for a body subjected to a force of 5 N. The correct expression for power, derived from the work-energy principle, is P(t) = (25/16)t, where the work done W(t) is W(t) = (25/16)t². The participants clarify that instantaneous power is determined by differentiating the work done with respect to time, rather than averaging over time. The final velocity at time t is established as v(t) = (5/8)t.
  • Newton's laws of motion
  • Basic calculus (integration and differentiation)
  • Work-energy principle
  • Understanding of instantaneous vs. average power
  • Study the relationship between force, mass, and acceleration in dynamics
  • Learn about the work-energy theorem and its applications
  • Explore differentiation techniques for calculating instantaneous rates
  • Investigate the concept of power in physics, including average and instantaneous power
Students of physics, educators teaching mechanics, and anyone interested in the principles of dynamics and energy calculations.
hk4491
A force of 5 N acts upon a body of 8 kg in the +x direction. Formulate an expression for the power generated as a function of time. The body is in the beginning at t=0 and x=0 (Sorry I'm translating this question from German, so excuse the mistakes).
Work = Force * distance
Power = ΔW/Δt
Force = mass * acceleration
Since the force of 5N is acting on the body, by Newton's third law, it is also exerting the same force, so that:
F = m * a
5 = 8*a
a=5/8 m/s^2
By integrating the acceleration twice I get the distance as a function of time:
x(t) = 5/8 t^2
Work = Force * distance = 5 * (5/8)t^2 = (25/8)t^2
P(t) = (25/8)t
Was my method correct?
x(t) = 5/8 t^2
You forgot something in doing that integration.
P(t) = (25/8)t
You have divided the total work done over the distance by the total time taken. That will give you average power, but I think it is the instantaneous power at time t that is wanted.
Thanks I realized my mistake in the integration part. That leads to x(t)= 5/16 t^2.
The body starts moving at t0=0, so at any given point of time Δt = t - t0 = t
Hence:
P= (F*d)/t
P(t) = 25/16 t
Hence:
P= (F*d)/t
P(t) = 25/16 t
No. You missed out a factor of half in your integration, so the correct expression for total work done at time t should be ##W(t) = \frac{25}{16}t^2##. This expression is not linear in t, so can you simply divide by t to find the power at time t? Shouldn't you be differentiating?
Basically, your original expression was correct - simply because your errors "cancelled out". You missed a half when integrating, then divided instead of differentiating, so you didn't include a requisite factor of 2.
Great, thanks for the explanation!
Another way of arriving at the answer is to remember that the instantaneous power is equal to the force times the velocity. The velocity at time t is 5t/8.
  • · Replies 38 ·
