Calculating Power Requirements for Electric Bikes on Inclined Terrain
  • Context: Undergrad
  • Thread starter Thread starter stilbiker
    Hill Power
The discussion centers around calculating the power requirements for an electric bike to climb a 20° slope, considering the weight of the bike and rider. Participants explore various assumptions about speed, power needs, and the performance of electric bike motors.
  • Rudy inquires about the power needed to climb a slope with a specific weight, initiating the discussion.
  • Some participants note that the power required depends on the desired speed while climbing the slope.
  • One participant calculates the additional power needed using a formula that incorporates total mass, gravitational force, and the sine of the slope angle, arriving at approximately 14.9 kW for a speed of 80 km/h.
  • Another participant suggests that at a lower speed of 5 km/h, the additional power requirement may be around 1 kW, recommending a 33% margin on the motor rating.
  • Concerns are raised about the reliability of power ratings provided by manufacturers, particularly for motors sourced from China, and the performance of batteries and controllers is questioned.
  • Rudy mentions having a 2 kW electric bike that struggles with the incline, indicating a need for a more powerful motor.
Participants express differing views on the power requirements based on varying speeds and conditions, with no consensus reached on the exact power needed for the climb.
Assumptions about steady speed, efficiency losses, and motor capabilities are discussed, but specific details about the bike's performance under load and the accuracy of manufacturer specifications remain unresolved.
stilbiker
Good Morning to evryboby.
What is the power needed to climb a 20° slope with a 100Kg electric bike + 100Kg for the driver?
Many thanks in advance.
Regards to all. Rudy
Hi stilbiker. :welcome:
The power needed depends on how quickly you'd like the bike to travel up that slope. Do you have a desired speed in mind?
m_total= 100kg + 100kg= 200kg
Assumption: The bike already has a steady speed (say 80km/h) before going up the slope ( before going up hill, the engine has been producing constant power for the bike to go steadily, constant power does not mean the bike will accelerate, as some of the energy produced is lost through vibration, noise etc until the total energy in the system is constant and so it is in steady state and does not accelerate ). The speed of bike is to remain the same during climbing. Assume the ADDITIONAL power needed is constant.
The additional power needed, P_needed is the work needed to be done per unit time to rise the elevation of the bike.
P_needed
= m_total*g*Δz/Δt
sinθ= z/s ,s is the displacement on the slope
z=s*sinθ
Δz= (Δs)(sinθ)
P_needed
= m_total*g*(sinθ)*(Δs)/Δt ,we want it to maintain speed (Δs/Δt) of 80km/h during the climb
= 200kg*9.81(m/s^2)(sin20)(80km/h)*[(1m/s)/(3.6km/h)]*[(1kW)/(1000kgm^2/s^3)] ,since 1kW=1kJ/s=1000kgm^2/s^3
= 14.91207825 kW
which is about 20 hp.
Don't worry about the unit conversion at first. You may "match up" the units to the SI base unit of Watt later.
Hello NascentOxygen. Many thanks for you answer. the speed may be very low, just to access my house, let's say 5 Km/h.
best regards
Hello Curiosity 1.
Many thanks for your answer. Wow 14 KW ! The bike will already have a steady speed (say 20km/h) before going up the slope ( before going up hill, the engine has been producing constant power for the bike to go steadily). The speed of the bike can fall to 5Km/h during climbing, only to reach my house.(about 500 m)
I already bought a 2 KW electric bike who's supposed be able to climb 20 deg. according to the specifications. IT FAIL! I intend to replace the motor with a stronger one.
But 14 KW hub motor is not available.
Best regards.
My figures show that at 5km/hr it will take about an extra 1kw to travel up a 20° slope than for the same speed on the level. (Then I'd throw in a 33% margin on the motor rating.) So do you have a way to measure the amps your bike draws at 5km/hr on a level road?
As far as bike motors go, I'd be a bit chary of the figures sellers may quote, especially if the motors come from China. Also, your batteries & controller may not be as ideal as you'd wish. What are the ratings for the batteries you are using?
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 18 ·
17K
  • · Replies 23 ·
  • · Replies 25 ·
12K
