Calculating recession vs attraction
  • Context: Undergrad
  • Thread starter Thread starter richardSPM
    Attraction
The discussion revolves around calculating the distance from a galaxy or galaxy cluster where the effects of gravitational attraction cease and the influence of dark energy begins to dominate, particularly in the context of cosmic expansion. Participants explore theoretical frameworks and models related to cosmology, including the use of supernovae as distance indicators and the implications of mass on space-time curvature.
  • One participant inquires about the calculation of the distance from a galaxy where its gravitational attraction no longer affects space-time curvature.
  • Another participant suggests that dark energy does not play a role in the initial calculations and refers to a resource for understanding distance measurements.
  • A participant expresses understanding of using supernovae as standard candles but seeks clarification on the distance where expansion begins to dominate over attraction.
  • Technical discussions reference the influence of cosmological expansion on local dynamics and mention specific studies that explore these concepts.
  • There is a mention of a personal theory (SPM) regarding the critical density and its implications for recession distances, which is challenged by another participant who states it is not aligned with mainstream LCDM cosmology.
  • Concerns are raised about the appropriateness of discussing personal theories in the context of the forum's guidelines.
Participants express differing views on the validity of the SPM theory, with some asserting that it does not align with accepted cosmological models. The discussion remains unresolved regarding the specifics of the calculations and the implications of different theories.
The discussion includes references to specific studies and models, but there are limitations in terms of consensus on the validity of personal theories versus mainstream cosmological models. The calculations and assumptions involved in determining distances related to gravitational effects and dark energy are not fully resolved.
richardSPM
How does one calculate the distance from a galaxy or galaxy cluster where recession due to dark energy begins and "attraction" ends?
Space news on Phys.org
https://www.sciencemeetsreligion.org/physics/distance.php
The above may help. Dark energy does not play a role in this description. Dark energy is inferred when Doppler shift distance measurement is compared with that described in the reference - particularly using supernovae type 1a.
Thank you for your prompt reply. I do understand the idea behind using supernovae type 1a as a standard candle to calculate distance and red shift to calculate the recession rate. What I am trying to ask is, If you have an object, galaxy or galaxy cluster, of known mass how does one calculate the distance from said galaxy where it no longer has an effect on the curvature of space-time? (ie there is no longer an attractive force) I assume it would be at this distance that expansion would begin to cause recession.
Are you looking for the actual equations used to calculate things? Or just a layman's description?
I'll take either.
A good technical discussion can be found in: On the influence of the global cosmological expansion on the local dynamics in the Solar System, Carrera et al. They do extend it to larger scales as well.
For what it's worth, I once used it to calculate the radius from the center of an isolated, spherical mass, where the accelerated expansion would cause a non-orbiting (stationary relative to the mass) particle to drift off and not fall into the cluster. This depends essentially just on the mass, Ho and the cosmological constant (lambda). In such a hypothetical (isolated) case, a free particle will always fall in if there is no lambda. If you are interested, also look at the Tethered Galaxy scenario, Davis et. al.
Hi Jorrie,
Thanks for responding. According to the SPM, recession would begin at a distance equal to the radius of a sphere that had a density equal to the critical density with the object at its center. Is this not a currently accepted premise based on LCDM?
Hi Richard, if I remembered correctly, SPM is a personal theory of yours that we did discuss on another forum. If I'm correct, then discussion of SPM is not allowed on this forum, which is reserved for mainstream theory and papers published in scientifically reputable media. I trust that you have read the general forum guidelines?
The short answer to your question is: no, the LCDM model, coupled to present observations, do not support such a model or premise.
And if that is the case, then @Jorrie is correct that it's out of bounds for discussion here.
In any case, the substantive question posed in the OP appears to have been answered, so either way this thread can be closed. @richardSPM , please review the PF guidelines as @Jorrie suggested. If you want to discuss SPM here, you will need to provide valid references (published peer-reviewed papers) as a basis for discussion.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 28 ·
  • · Replies 37 ·
