Calculating Rotational Speed for 2g Experience in a Rotating Machine
To determine the rotational speed required for a 75.8 kg astronaut to experience a force of 2g in a rotating machine with a 6.25 m radius, the centripetal force formula F = (m*v^2)/r is appropriate. The astronaut's weight is doubled to account for the 2g experience, meaning the force exerted must equal 2mg. The mass of the machine is not relevant to the calculation, as only the astronaut's mass is considered. The correct approach involves equating the centripetal force to 2mg to find the necessary speed. This confirms that the formula is valid for this scenario.
jtizzleg
A NASA astronaut is placed in a rotating machine to see how well their bodies withstand G Force.
What rotational speed is needed in a device that has a 6.25 m radius to allow a 75.8 kg astronaut to experience a force that is twice his normal weight (or 2g)?
Centripedal Force formula:
F = (m*v^2)/r
I am wondering if that's the right equation, as it's the only equation I've found to use the radius of the machine, force, and mass given.
Just trying to confirm some things:
Do I assume the machine has no mass? No mass for the machine is given to be summed to the mass of the astronaut, so I assume that the only mass I calculate.
Do I multiply the mass by two? since I'm trying to find the speed needed for the machine to exert double his mass.
Also, is this even the right formula? Or did I get something wrong?
Edit: Scratch that second question, just figured that the Force would be the 2g, while the mass I'm assuming is his weight alone, unless I have to account for the machine's mass too.
your formula is right. equate it with 2mg. the mass of the machine doesn't play any role.
