Calculating Rotational Speed on a Giant Wheel
  • Thread starter Thread starter Ishida52134
    Circulation Motion
9 replies · 16K views
Ishida52134
A giant wheel, 40m in diameter, is fitted with a cage and platform on which a man can stand.
The wheel rotates at such a speed that when the cage is at X (as shown) the force exerted by
the man on the platform is equal to his weight. The speed of the man is:
X is located at the top of the vertical wheel.
A. 14m/s
B. 20m/s
C. 28m/s
D. 80m/s
E. 120m/s
Fn + Fg = ma
Well it states the normal force is mg. So I got 2mg = m(v^2/r)
which I got that v = 28 m/s.
But the answer key says it's b.
A. 14m/s
B. 20m/s
C. 28m/s
D. 80m/s
E. 120m/s
Fn + Fg = ma
your method is correct I believe you just made a computational error.
it's 2mg = mv^2/r
so v = sqrt (2gr) which is sqrt(784) = 28.
I don't know how to put an image up.
Basically it's just a vertical circle and point X is at the top of it.
It appears to me that you are using the diameter in your calculation rather than the radius.
2mg = m*v^2/r
v = sqrt(2gr)
v = sqrt(2*(9.8m/s^2)*20m)
v = sqrt(392) = 19.798 which rounds up to 20 m/s
If you do the same math with r = 40 you get 28 m/s. However, the question states that the diameter is 40, so the radius must be 20.
Ishida52134 said:
any ideas
Take g = 10 m/s^2. Then 2gr = ? ( 2r = diameter)
Ishida52134 said:
it's 2mg = mv^2/r
the reason you keep getting sqrt(784) is because you are using 40m for radius when you should be using 20m
