Calculating Support Reaction Forces using Method of Joints
daphnelee-mh
Summary:: The question requires us to determine the member forces using method of joints but I couldn’t figure out how to calculate the support reaction forces
I tried to use equilibrium equations to solve the question but the force applied will be canceled out, and eventually the reaction force will be zero
  • Handwritten work for a truss problem, part (c): a truss with supports G and H, loads P1 and P2, and members labelled B, E, D, A, C, F, with span 4a and height a; beside it are moment and force equations and joint diagrams for joints E and B.
Summary:: The question requires us to determine the axial forces using method of sections but it is statically indetermine structure
Can I make up one more equation by summing the moment at point O ?
  • Two truss diagrams labelled (f): the top shows a 6x4=24m truss with 10kN loads at the top joints, 20kN at the right end, supports labelled FAy, FBy and FCy, and joints labelled D, E, F, G, H; the bottom shows the same truss with a red circle marking joint O and the equations for sum of Fy and sum of moments about C.
Will the support reaction forces G and H not sum to the weight of the structure, plus the load ?
Sorry I don’t understand
