Calculating Tension and Speed in a Centripetal Force Problem
  • Thread starter kengreen
    Centripetal
13 replies · 2K views · last reply
kengreen
A model airplane whose mass is 875 grams flies in a horizontal circle of radius 3.46 m at the end of a string which is at an angle 10.5 degrees below the horizontal. Find:
a) the tension in the string
b) the speed of the airplane
Fc=T=mv^2/r Ac=v^2/r
im not sure if i am given enough information to solve this problem because i don't have the acceleration or velocity
You have.I think you could try to analyze the forces to their components and make a relation between the vertical component of tension and the weight.
i think the vertical component of tension has to cancel the weight? am i correct in where i a m going with this.
I am sorry i misguide you.Vertical component of tension cannot cancel the weight because they are both pointing down unless i misunderstood the picture.could yuo please draw me an image of the ecxercise?
if this is the case then what i told you is correct.That should be the case bacouse otherwise it would drop
  • Hand-drawn sketch of a conical pendulum: a bob on a string hanging from a horizontal ceiling line, with a dashed elliptical path traced beneath it in a horizontal plane.
okay well i have the answer to the first question because i talked to my professor but i just don't understand how this is the answer. he said that it is 47.1 N.
there is no picture. its just a word problem. the thing that is throwing me off is that in the problem it states that the end of the string is at an angle 10.5 degrees below the horizontal.
If the draw is the one i made you then it is correct the 47.1.Approximatelly.Tsin10.5=Mg
I donnot know it should say above or else it could not be possible to rotate it would fall.ask your teacher about it
