Calculating the Area Bounded by Two Curves
9 replies · 4K views · last reply
the white sou
find the Area Bounded by the two curves, y=|x+1|, y= - ( x+1)2 + 6
A= Integration of | f (x) - g(x) |
x+1= f(x)
-(x+1)2 + 6= g(x)
getting the limit of integration:
x+1= - (x+1)2 + 6
x2 + 3x - 4=0
(X+4) ( x-1)
so x=-4, and x=1
now when dividing the absolute valuey= x+1 ; x<-1
y=-(x+1) ; x>-1Integration is denoted by { ( upper limit , lower limit ) |f(x)|
so the Area= {(-1,-4) |(-x-1) + (x+1)2 -6 | - {(-1,1) |(x+1)+(x+1)2 - 6|what's wrong in this solution, I think that we should use -x-1 to get the limits as well so the area will be (the integration from -4 to -1) - (the integration from -1 to 3)
welcome to pf!
hi the white sou!
…getting the limit of integration:
x+1= - (x+1)2 + 6
x2 + 3x - 4=0
(X+4) ( x-1)
so x=-4, and x=1
No … you need to use |x+1|, not x+1. :wink:
Graph it first.
Looks like you are using -4 as one of your limit however,
at -4
y = 3, y = -3
They don't intersect at -4
(tiny-tim already pointed out)
tiny-tim said:
hi the white sou!
okay |x+1| consists of x+1, -x-1
once we use x+1=-(x+1)2 +6
x= 1, x= -4
and when we are using -x-1= -(x+1)2 + 6
we get x=-2, x=3
now we are having 4 points of intersection
soo how would we get the limits
rootX said:
Graph it first.
at -4
y = 3, y = -3
I already graphed it
for |x+1| there will be two lines intersecting at the point -1 and for the other curve we are having the the head of the curve at (-1,6) and it is opening downword
When you used x+1, you got x= 1, x= -4
When you used -(x+1), you got x=-2, x=3
Does x+1 is right or left line in the curve |x+1|. Label |x+1| with x+1 and -(x+1) and you should be able to identify which two of the above four solutions is valid
An alternative method:
both curves are obviously symmetric about the line x + 1 = 0, ie x = -1,
so the solutions must also be symmetric about x = -1. :wink:
so Area= {(-2,-1) |f(x)-g(x)| - {(-1,1) |f(x)-g(x)|
am i right now?
am i right now?
1)
and when we are using -x-1= -(x+1)^2 + 6
we get x=-2, x=3
Should have been
x= 2, x=-3
