Calculating the Force of the Deltoid Muscle to Raise an Arm
  • Thread starter Thread starter Eggphys
    Arm Force Muscle
The discussion focuses on calculating the force exerted by the deltoid muscle to raise an arm, considering the forces of gravity and the shoulder socket. Participants express confusion about how to incorporate the angle of the deltoid's force and the correct application of Newton's laws. Initial calculations for gravitational force yield 15.39 N, but attempts to derive the deltoid force result in an incorrect value of 14.98 N instead of the expected 67.38 N. Clarification on force decomposition and angle application is sought to resolve the discrepancies in calculations. The thread emphasizes the importance of correctly applying physics principles to solve the problem.
Eggphys
The main muscle responsible for raising an arm is the deltoid. The deltoid muscle connects at the upper end of the shoulder, extends over the upper arm bone (humerus), and attaches near the elbow. Effectively there are three forces involved in raising the arm: (i) the force of the deltoid muscle, Fm, acting at an angle of approximately 13.2o with respect to the negative x axis, (ii) the force of gravity, Fg, acting effectively at the centre of mass of the arm located close to the elbow, and (iii) the force of the shoulder socket, Fs, acting on the humerus effectively along the x axis. Assuming the mass of the arm is 1.57 kg, calculate the magnitude of Fm in Newton.
F=ma
I'm not quite sure where to start. I tried using F_x=ma and F_y=ma to work out the net force but not getting the correct answer. Any help would be greatly appreciated. Thanks.
Sorry I made a mistake you can do it with just Newtons law no torques needed . Can you show your actual work force decomposition should work if you didn't do any calculation mistakes?
After going over my work abit more I see I have no clue what I am doing:frown:
Im not sure how to implement the angle into the equation or what a is in the x direction(Isnt it 0?)
Would Fy just be Fy=1.56*9.8?
Any help on where to start would be great. Thanks:smile:
So i decided to come at this from another angle. First i solved for Fg,
Fg=1.57*9.8 = 15.39
Then to solve for Fm,
Fm=15.39cos 13.2 = 14.98
But the correct answer is 67.38. I am not sure where to go from here to get the correct answer. Any help would be appreciated. Thanks:smile:
Just bumping back to the top.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
