Calculating the quantum state of an electron
The discussion revolves around calculating the quantum state of an electron in a hydrogen atom transitioning from an excited state to the ground state, with a focus on the relationship between kinetic energy and wavelength. The initial calculations used the kinetic energy equation and the Rydberg energy equation, leading to an incorrect conclusion about the quantum state. Participants highlighted the need to consider the de Broglie wavelength and the difference in energy levels rather than equating kinetic energy directly to the energy of the electron in the atom. Ultimately, the correct approach involves using the wavelength of the emitted photon to determine the initial and final quantum states, resulting in a conclusion that the electron likely fell from the seventh quantum state. The discussion emphasizes the importance of accurately interpreting the problem and using the appropriate formulas.
bbbl67
An electron in a hydrogen atom falling from an excited state to the ground state has the same wavelength than an electron moving at a speed of 7821 ms^-1. From which excited state did the electron fall from?
I used the kinetic energy equation:
K = (m v^2)/2
m = 1 m_e = 9.109383×10^-31 kg
v = 7821 m/s
I also used the Rydberg Energy equation:
E_n = -h c R_inf Z^2 / n^2 |
E_n | electron energy
h | Planck constant
c | speed of light
R_inf | Rydberg constant at infinity
Z | atomic number
n | quantum number
Z = 1 (since it's hydrogen)
n = quantum number = ? (this is what we are trying to find)
The constant (h c R_inf) is also known as the Rydberg unit of energy, Ry:
Ry = h c R_inf = 13.60569 eV
So this was in somebody's chemistry textbook, and I thought I'd try to solve this for giggles. I got no chemistry background, except in high school. I knew the kinetic energy equation by heart, I had to google the Rydberg equation (https://is.gd/QhBP9Z). I wonder if my logic is correct here?
kinetic energy:
K = 2.786×10^-23 J = 1.739×10^-4 eV
quantum energy:
E_n = - Ry Z^2 / n^2
Since we're only looking for the magnitude in energy differences, I think we can ignore the negative sign in the equation, and simply write it as:
E_n = Ry Z^2 / n^2
So we set,
E_n = K
K = Ry Z^2 / n^2
n^2 = Ry Z^2 / K
n = sqrt(Ry Z^2 / K)
= sqrt(13.60569 eV * 1^2 / 1.739×10^-4 eV)
= 279.7
~ 280
Conclusion: So that would mean that the electron fell from the 280th quantum state.
How was my logic about this? Is there any other way of solving this?
Please use LaTeX
Your energy comes out as 0.1 meV range. Something is wrong. Typical energies in atoms are eV. I don't really understand the question
bbbl67 said:
An electron in a hydrogen atom falling from an excited state to the ground state has the same wavelength ...
So which state is meant here, the excited one or the ground-state? Also, why is there emphasis on the wavelength? You don't seem to be using this bit at all in your solution. Of course, if the question does mean that the energy of the excited atom was ##-\frac{m_e (7821 \,\mbox{m/s})^2}{2}## then the quantum number of this state will be very high. Then your answer makes sense, though I think the relationship between the kinetic energy of the electron and the full energy of the atom is slightly different (use Virial Theorem).
Cryo said:
Please use LaTeX
Well, the electron is traveling really fast almost 8 km/s, so it has a lot of kinetic energy.
Well, the wavelength just corresponds to being at the same energy level. Yes, well the 280th energy level would be a pretty high energy level.
The energy of the electron in the atom is not equal to the kinetic energy of the free electron. It is the wavelengths that are the same. (Strictly, the question should have said "the wavelength of the photon emitted when an electron falls...")
For the atom: you need the difference in energy between the two levels, not just the energy of one level. (The ground state energy is not zero!)
For the free electron: you need the de Broglie wavelength.
Likes bbbl67
Typical energies in atomic physics are eV, so relative to that your 8 km/s electron does not have a lot of energy.
Ah, I get it now. Used the wrong formula:
λ = h/(m v) |
λ | wavelength
m | mass
v | velocity
h | Planck constant (≈ 6.62607×10^-34 J s)
λ = 6.62607×10^-34 J s / (9.109383×10^-31 kg * 7821 m/s)
= 93 nm
(https://is.gd/lLLYYt)
1/λ = R_∞ Z^2 abs(1/n_f^2 - 1/n_i^2) |
λ | photon wavelength
n_f | principal quantum number of final state
n_i | principal quantum number of initial state
Z | atomic number
R_∞ | Rydberg constant (≈ 1.0973731569×10^7 m^(-1))
Z = 1
n_i = 1
λ = 93
n_f = ?
= 7
(https://is.gd/WWIzB7)
Does this make more sense?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
