Calculating the Solution for a Falling Object with Air Resistance
  • Thread starter Thread starter Opressor
8 replies · 3K views · last reply
Opressor
A body falling under the action of the drag force of the air -βvn
n ∈ ℤ
m= mass
v= velocity
g= 9,8m/s2
β= coefficient of air resistance
m(dv/dt)= mg-βvn
I can not resolve to any integer (n)
$$m\frac {dv} {dt} =mg- β v^n$$
You can use separation of variables to solve the case for n=2 (maybe it can be applied to higher n as well).
##\frac{dv}{dt}=g(1-\frac{\beta}{mg}v^2)\Rightarrow \frac{dv}{g(1-\frac{\beta}{mg}v^2)}=dt## and now all you have to do is integrate both sides.
You can take a look at https://en.wikipedia.org/wiki/Terminal_velocity#Derivation_for_terminal_velocity if you want more details (click show on that derivation link in the Wikipedia page).
thank you
Does it treat this equation as Bernoulli's equation?
$$\frac {dy} {dx}\ +P(x)=Q(x)y^n$$
Bernoulli's differential equation is slightly different, it has a y-term it is ##\frac{dy}{dx}+P(x)y=Q(x)y^n##.
Are you sure that n is allowed to take values higher than 2? Because the drag force cases I know are either n=1 or n=2, never heard of a drag force ##-bv^3##.
In case that ##n\geq 3## it seems that the solution involves calculation of the following integral
$$\int \frac{dv}{1-av^n}$$
which doesn't have a closed form, so I believe (I am not completely sure) that for ##n\geq 3## the solution doesn't have a closed form.
If ##J_n = \int 1/(1-a v^n) \, dv,## then
Maple gets J34 = -(1/3)*ln(v-(1/a)^(1/3))/(a*(1/a)^(2/3))+(1/6)*ln(v^2+v*(1/a)^(1/3)+(1/a)^(2/3))/(a*(1/a)^(2/3))+(1/3)*3^(1/2)*arctan((1/3)*3^(1/2)*(2*v/(1/a)^(1/3)+1))/(a*(1/a)^(2/3))
and
J4 = (1/2)*(1/a)^(1/4)*arctan(v/(1/a)^(1/4))+(1/4)*(1/a)^(1/4)*ln((v+(1/a)^(1/4))/(v-(1/a)^(1/4)))
Furthermore, these check out when differentiating them wrt v.
Both of these are closed forms.
What is even more surprising to me is that Maple gets a (lengthy and horrible) closed-form for J5.
Well ok, to be honest I check it with wolfram and it showed as result the incomplete beta function of some sort.
Even if ##J_n## has closed form, we then have to solve the equation ##J_n(v)=t+C\Rightarrow v=…## which I believe would not be possible, so the solution will not be in explicit form.
You could expand the integrand using partial fractions and then integrate each term. It's probably not that bad of a calculation, actually, now that I think about it.
