Calculating the Spring Constant k of a Spring
19 replies · 3K views
jimithing71
To stretch a spring a distance of 0.20m 30J of work is done. What is the value of the spring constant k of the spring?
a)6 b)30 c)150 d)1500 e)none of the above
I know that the answer is D 1500 but I can't quite arrive at that.
The two formulas I thought to try were F=-kx and PE=1/2kx^2 but those didn't work. Then, after a bit of perusing on here I found k=mg/x.
Thus, 30(9.8)/.20 = 1470 ...which is close to 1500 but is that correct??
Try again. Note that these formulas are for very different things. Only one of them relates to work/energy.
Nah.
My head is starting to hurt! LOL!
Okay, so now I tried F=-kx, 30J=-k(.20m), 30J/.20m=-k, 150=k
That is one of the options (C), but our instructor told us the answer was (D) 1500. ?
You picked the wrong equation. F is force, not work. (PE is energy/work)
One more time.
Thank you! PE=1/2kx^6, 30=1/2k(.04), 30/.04=1/2k(.04)/.04, 750=1/2k, 1500=k Whew!
One more?
A roller coaster car with a mass of 900kg starts at rest from a point 20m above ground. At point B it is 12m above ground. If the initial KE was 0 and the work done against friction between the starting point and point B is 30,000J, what is the KE at point B?
a)10.8kJ b)20kJ c)30dj d)40kJ e) none of the above.
I know the answer is 40 kJ but I'm not sure which equation to use at all. The only one in my notes that seems close is KE=1/2mv^2 but that isn't working.
You need to worry about total mechanical energy: KE + PE. What's the formula for gravitational PE?
G=6.67X10^-11* N*m^2/kg^2 ??
Or wait! Is it PE=mgh??
cupid.callin said:
yes it is
Which one?
Sorry but I don't get that at ALL! That would be PE=(900kg)(9.8g)(20m), PE= 176,400? What am I missing?
You need to compare total mechanical energy at the starting point to that at point B. What happens to the total mechanical energy because of friction?
It would be slowed due to friction? I am really lost on this one. I did the PE=mgh for point A and for point B and subtracted the two and got 70,560 so obviously that is wrong as well.
Hint: If there were no friction, then:
KEA + PEA = KEB + PEB
How would you have to modify this to incorporate the energy lost to friction?
I wish I knew!
Okay, last attempt:
KE(a) + PE(a) = KE(b) + PE(b)
0 + 176,400 = KE(b) + 105,840 + 30,000
176,400 - 105,840 - 30,000 = KE(b)
40,560 = KE(b)
jimithing71 said:
I wish I knew!
Okay, last attempt:
40,560 = KE(b)
Looks OK to me. One of the answer choices is pretty close.
LOVE YOU Doc Al! Thanks for all your help! Time for a glass of vino! :0)
