Calculating the Tension in Cables for Elevator Movement
The discussion focuses on calculating the tension in two cables supporting an 85 kg piece of machinery being moved by an elevator accelerating upwards at 0.2 m/s². The cables are positioned at angles of 22 degrees and 40 degrees below the horizontal. Participants emphasized the importance of drawing a free body diagram to visualize the forces acting on the equipment, including the weight and the tension forces. The correct application of Newton's laws, particularly in resolving the forces into their x and y components, is crucial for solving the simultaneous equations to find the tension in each cable.
  • Understanding of Newton's laws of motion
  • Knowledge of vector resolution and trigonometric functions
  • Ability to draw and interpret free body diagrams
  • Familiarity with basic mechanics concepts, including force and acceleration
  • Study the process of resolving forces into x and y components
  • Learn how to draw and analyze free body diagrams in mechanics
  • Explore simultaneous equations and methods for solving them
  • Review applications of Newton's second law in various contexts
Students studying physics, particularly those focusing on mechanics, engineers involved in machinery design, and anyone interested in understanding the dynamics of forces in systems involving pulleys and cables.
hayley123
a hevy piece of macinery(85kg) is being moved by elevator between floors in a building. Two identical small cranes are used. a cable connects each 'crane' to a mounting hook on the top of the piece of equipment. the cable from one crane is at an angle of 22degrees below the horizontal while the cable from the other hangs at 40 degrees. find the tension in each cable if the elevator is accelerating upwards at a constant 0.2ms^-2. and i need to include a vector diagram
im thinking ticos22-t2cos40-0
ti=N/sin22something
i drew a picture of what i thought it might look like and I am honestly so baffled.
The equipment is being held up by 2 cables at the angles noted. It is not in contact with the floor. The horiz comp of each cable tension force acting on the equipment uses the cos function as I think you were addressing. There's no acc in x direction, so Newton 1 applies in that direction. Now in the vert direction, what are the vert comp of each tension force, and what other force acts in the vert direction? Use Newton 2 in that dir. Solve the resulting equations.
omg I am still confused haha but ill go through what you said step by step and see how i go thanks
ok so far i did f=ma
F=85x9.8-0.2m/s-2
F=812N
so that's the force acting on the cables yeah?
108N i mean
ah nah I am way off i think
You need to draw a free body diagram sketch that shows all forces acting on the equipment...its weight acting down and the 2 tension forces acting upwards at the given angles. Break up each tension force into its x and y components. Note directions.
In the x direction, apply Newton 1, and in the y direction, apply Newton 2. You are not correctly using Newton's laws. In the y direction, for example, Newton 2 says that the net force in that direction is equal to product of the mass times its acceleration in that direction. The net force in the y direction is the algebraic sum of the weight and vert comps of the tension forces. Set that net force equal to ma... i don't see any equal signs in your incorrect equation. You then have to look in the x direction as well to get another equation (using F_net = 0 in that direction), and solve the 2 simultaneous equations for the unknown tension forces.
ah ty ty ty think I've got it now thanks heaps for your help.
24K
49K
