Calculating Torque for Helicopter Blade Rotation
The discussion focuses on calculating the torque required for a helicopter blade with a length of 7.8 m and mass of 100 kg to reach an angular speed of 320 revolutions per minute in 6.70 seconds. The correct moment of inertia for the blade, treated as a uniform rod, is determined to be 1/3 mL² using the parallel axis theorem. The torque exerted by the bolt must be 7.6 x 10³ N·m, calculated using the formula T = Iα, where I is the moment of inertia and α is the angular acceleration of 5 rad/s².
  • Understanding of torque and angular acceleration
  • Familiarity with the moment of inertia for different shapes
  • Knowledge of the parallel axis theorem
  • Basic proficiency in rotational dynamics equations
  • Study the derivation and application of the parallel axis theorem
  • Learn about calculating moment of inertia for various geometric shapes
  • Explore angular motion equations in detail, particularly T = Iα
  • Investigate real-world applications of torque in mechanical systems
Students studying physics, mechanical engineers, and anyone interested in the dynamics of rotating systems, particularly in aerospace applications.
9giddjl
Consider a simple helicopter blade, attached to a bolt at its end. The bolt is made to rotate by a powerful motor, and the blade therefore rotates. The blade has a length L= 7.8 m and mass M= 100 kg. The blade is shaped approximately like a long thin, uniform rod.
What torque must the bolt exert on the blade in order to bring it from rest to full angular speed 320 rev/min in time t= 6.70 s
Before, I worked out the force that ther bolt exerts on the blade when the blade is spinning at full speed to be 4.4 x 10^5 N. thus, force= 4.4 x 10^5 N. I thought that i could just find the angular acceleration: wf=wi + at and then find the moment of inertia and use T=Ia but i don't know what the moment of inertia would be. Would it be 1/12mL^2 or 1/3mL^2
I found the angular acceleration to be 5/rad/s^2.. but i just don't know what the moment of inertia would be becoz i worked them out using the above equations and i keep getting the wrong answer. the right answer is 7.6 x 10^3 N.m. Is T=Ia the right formula to be using or am i on the wrong track? Any help would be muchly appreciated! thankyou!
9giddjl said:
… use T=Ia but i don't know what the moment of inertia would be. Would it be 1/12mL^2 or 1/3mL^2
Hi 9giddjl! :smile:
(try using the X2 tag just above the Reply box :wink:)
It's 1/12 mL2 about the centre of a rod,
and using the parallel axis theorem it's 1/12 mL2 + 1/4 mL2 = 1/3 mL2 about the end :wink:
i used 1/2 ML^2 for the moment of inertia and it yielded the correct answer! thankyou for ur help wise teacher!:)
9K
