Calculating vector cross product through unit vectors
The discussion focuses on calculating the vector cross product using unit vectors. Participants emphasize the importance of the determinant form for simplifying calculations and reference the distributive property and basic equations of cross products involving unit vectors. Key relationships such as ##\hat{i} \times \hat{j} = \hat{k}## and the anticommutative property are highlighted as essential for understanding the process. One user expresses frustration with the complexity of deriving the cross product without using determinants. Overall, the determinant method is favored for its efficiency in computing cross products.
greg_rack
Derive the formula for calculating: ##\vec{U}\times \vec{B}##
none
Writing both ##\vec{U}## and ##\vec{B}## with magnitude in all the three spatial coordinates:
\vec{U}\times \vec{B}=
(U_{x}\cdot \widehat{i}+U_{y}\cdot \widehat{j}+U_{z}\cdot \widehat{k})\times
(B_{x}\cdot \widehat{i}+B_{y}\cdot \widehat{j}+B_{z}\cdot \widehat{k})$$
From this point on, I cannot understand the calculations needed to obtain the final formula:
\widehat{i}(U_{y}B_{z}-U_{z}B_{y})... $$
Likes Delta2
What are the cross products of the unit vectors?
Have you seen the determinant form of the cross product? I almost always use that.
You have to use the distributive property (i.e ##\vec{a}\times(\vec{b}+\vec{c})=\vec{a}\times \vec{b}+\vec{a}\times\vec{c}) ## and also the following basic equations which follow from the definition of the cross product and its application on the unit vectors of a cartesian coordinate system:$$\hat i\times\hat j=\hat k,\hat j\times \hat k=\hat i, \hat k \times \hat i=\hat j$$ and also use the anticommutative property e.g ##\hat{j}\times\hat{i}=-(\hat i \times \hat j)=-\hat k##
Also the property $$\lambda \vec{i}\times\mu \vec{j}=\lambda\mu (\vec{i}\times\vec{j})$$.
Likes greg_rack
##\hat{i}\times \hat{j}=\hat{k}##
Unfortunately not... I know that's what everybody use, but we shouldn't
You use that plus the other rules that @Delta2 posted above.
Likes greg_rack and Delta2
Got it guys, thank you! @Delta2 @PeroK
Through the determinant it's way faster and easier, deriving it in this way is a pain
Likes Delta2
  • · Replies 16 ·
