Calculating velocity in regards to the mass and kinetic energy of an object
To calculate the velocity of a baseball with a mass of 145 g and 94 J of kinetic energy, the correct mass in kilograms is 0.145 kg, not 0.0145 kg. The formula used is v = √(2Ek/m), which leads to the calculation v = √(2 * 94 J / 0.145 kg). This results in a velocity of approximately 36 m/s, aligning with the book's answer. The confusion arose from using the incorrect mass value in the calculation.
v3ra
How fast is a baseball with a mass of 145 g traveling if it has 94 J of kinetic energy?
m = 145 g or 0.0145 kg
Ek = 94 J
v = ?
v = √2Ek/m
I get...
v = √2(94)/0.0145 kg
v = √12966
v = 114
But my book says it should be 36 m/s. What am I doing wrong?
It also mentions that I need to recall that 1 J = 1 kg . m^2/s^2 but I am unsure how to incorporate this into the equation or if it is even necessary.
Your mass should be .145 kg.
Your mass should be 0.145 kg and not 0.0145kg
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
