Calculating Velocity of a fluid (by thermal convection) from the heater power.
The discussion focuses on calculating the mean fluid velocity in a closed circuit using the power supplied to an electric heater and the resulting temperature rise. The approach involves applying the conservation of energy principle, where the heater power equals the product of mass flow rate, specific heat, and temperature rise. The mass flow rate can then be expressed in terms of fluid density, velocity, and cross-sectional area, allowing for the calculation of velocity. This method effectively combines thermodynamic principles with fluid dynamics to derive the desired velocity.
  • Understanding of thermodynamics, specifically energy conservation principles.
  • Familiarity with fluid dynamics concepts, including mass flow rate and velocity.
  • Knowledge of specific heat capacity and its role in heat transfer.
  • Basic understanding of Reynolds and Grashof numbers for fluid flow analysis.
  • Study the conservation of energy in fluid systems, focusing on energy balances.
  • Learn how to calculate mass flow rate using density and cross-sectional area.
  • Explore the application of Bernoulli's equation in fluid dynamics.
  • Investigate the relationship between temperature rise and heat transfer in fluids.
Students and professionals in mechanical engineering, particularly those involved in fluid dynamics, thermodynamics, and heat transfer analysis. This discussion is beneficial for anyone looking to understand the practical application of energy conservation in fluid systems.
Igloo_Boobs
Ok, I have some questions to answer for this lab report, and one of them has left me clueless. The experiment was as follows:
An apparatus is made of a rectangular circuit (of known dimensions) of tubes filled with water with thermometers visible at various points throughout the circuit. No water can enter or leave the circuit, only flow around it. The driving force for this is the convection caused by a heat exchanger at the top of one side of the circuit and an electric heater (of known power) at the bottom of the other side.
I have to calculate the mean fluid velocity in three ways.
The first was to simply inject some dye and measure the time taken.
The second was a theoretical calculation using Reynolds and Grashof numbers and what have you.
The third is the one I'm struggling with. Word for word it says "Calculate the mean velocity from the electrical power supplied to the heater and the consequent temperature rise across the heater."
Anyone got any ideas how I could go about part three?
I'm fine with the rest of it, I just have no idea how to appoach part three. I suspect Bernoulli or continuity equations may be involved, and I also think I'm not taking into account some vital piece of information.
TL: DR how can I calculate the velocity of a fluid in a circuit from the power of the heater?
This looks like a conservation of energy problem. You can assume that most of the power is converted to heat. That will be the energy added to the system. What heat not convected away from the module will increase the velocity of the fluid, neglecting pressure of height differences between the inlet and outlet.
Igloo_Boobs said:
...The third is the one I'm struggling with. Word for word it says "Calculate the mean velocity from the electrical power supplied to the heater and the consequent temperature rise across the heater."
An energy balance across the heater yields:
heater power = mass flow rate X specific heat X temperature rise across the heater
Solve for mass flow rate. The mass flow rate is related to velocity as:
mass flow rate = density X velocity X cross sectional area of flow
Solve for velocity.
That's it! That's exactly what I needed. Thanks so much.
