Calculating volume & moment of inertia
This discussion focuses on calculating the volume and moment of inertia for shapes defined by the equation |xn| + |yn| + |zn| = Rn. The user explores methods to compute volume using integrals, particularly for octahedrons (n=1) and spheres (n=2), and encounters challenges when applying the same approach for other values of n. The conversation highlights the necessity of modifying integration limits to ensure valid results, especially when calculating the moment of inertia by summing individual contributions from different sections of the shape.
  • Understanding of integral calculus, specifically double integrals.
  • Familiarity with geometric shapes and their properties, particularly octahedrons and spheres.
  • Knowledge of moment of inertia concepts in physics and engineering.
  • Experience with mathematical modeling and numerical approximation techniques.
  • Research advanced techniques for calculating volume using triple integrals.
  • Learn about numerical integration methods for approximating volumes of complex shapes.
  • Study the derivation and application of moment of inertia formulas for various geometric shapes.
  • Explore software tools for symbolic computation, such as Mathematica or MATLAB, to automate volume calculations.
Mathematicians, physicists, engineers, and students involved in geometric modeling, particularly those interested in volume and moment of inertia calculations for complex shapes.
power11110
Hi there,
I am trying to calculate both volume and moment of inertia of shapes which surface coordinates are depicted by following equation:
When n is 1 it is simple octahedron, when it is 2, it is sphere and then choosing any n, it becomes something else.
I will try to depict how I am trying to find volume.
Firstly, I am considering a 1/8 of the shape (because it's really symmetrical). To find out an area of little sheet of the shape: Area = ∫ x dy = ∫ (R^n - |y^n|)^(1/n) dy;
Which is alright. Now, what I am thinking, in order to find out volume I could do following integral:
∫ Area dR = ∫ ∫ (R^n - |y^n|)^(1/n) dy dR where boundaries, both of them, are 0 to R.
When I try to solve this equation, it only works for the sphere. For any other n, it gives false answer. Please, comment on it.
Speaking about moment of inertia, I was thinking once I understand and find how to depict all those sheets of the shape, I could try to find each ones moment of inertia and then add them all somehow.
Any help is appreciated, thank you.
How can you integrate over R, if R is a constant parameter? This integral should run over y or z. In addition, the area is not the same for all y (or z), so your formula for the area needs a modified limit.
Right.
Hmm, what do you think such for such expression then:
Volume = ∫∫( R^n - |y^n| - |z^n|)^(1/n) dy dz (from 0 to R, from 0 to R) ?
I know it does not work but I can't understand why it doesn't.
You'll have to adapt one integration limit a bit, otherwise you run into regions where the integrand is not well-defined. If you do that, it should work.
If I change first boundaries to: from 0 to (R-z) and change equation to:
∫∫|(R-z)^n - y^n|^(1/n) dy dz
It gives good results. Is that valid for every n?
That is not the right boundary (apart from n=1). How did you get that formula?
Hmm, yep, I can see that it does not work every n. What I was trying to do in the first place is to make a program which simply sums up my area integrals * increment (e.g. 0.001). If you start with 1/4 of the area, than every increment the equation shrinks and changes R value by 1 increment's value and also boundaries change accordingly. So if increment is small enough it gives a good approximation of Volume but it only uses one integral.
Area = Int ((R-z)^n - y^n)^(1/n) dy;
dV = Area * increment;
Change Z from 0 to R;
So I was trying to adapt that somehow to make it double integral.
  • · Replies 16 ·
