Calculating Volume of an Arbitrary Pyramid
  • Context: High School
  • Thread starter Thread starter Guest432
    Pyramid Volume
The discussion revolves around the mathematical derivation of the volume of an arbitrary pyramid, focusing on the relationship between cross-sectional area and height. Participants explore the scaling of areas and dimensions as one moves from the apex to the base of the pyramid, considering both general principles and specific mathematical formulations.
  • Some participants express a desire for a clearer mathematical explanation of the volume derivation from the article, particularly regarding the scaling of cross-sectional areas with height.
  • It is proposed that thinking downwards from the apex may clarify how the width of the pyramid at a given level relates to the height, suggesting that the area at that level is proportional to the square of the distance from the apex.
  • Participants discuss the constant of proportionality, denoted as ##k##, and how it relates to the area at the base and the height of the pyramid, leading to the formulation of the area at height ##z## as ##A(z) = A_b \frac{(h-z)^2}{h^2}##.
  • There is a question about the use of ##(h-z)^2## in the area formula, especially in the context of arbitrary pyramids, not just square-based ones.
  • Some participants explain that for any flat shape, increasing dimensions proportionally results in area increasing by the square of the scaling factor, providing a general mathematical principle behind the area calculations.
  • One participant seeks clarification on whether the reasoning is based on established mathematical laws or intuitive understanding.
  • It is stated that the principles discussed are standard mathematics involving the definition of area and multiplication, applicable to various shapes, though some caveats about unconventional mathematical concepts are noted.
Participants generally agree on the mathematical principles regarding area scaling, but there remains some uncertainty and debate about the specific application of these principles to arbitrary pyramids, particularly concerning the formulation of the area at different heights.
Some limitations are noted regarding the assumptions made about the shapes involved and the specific definitions of terms used in the discussion, which may affect the clarity of the mathematical derivations.
Guest432
I am trying to gain some understanding from this article regarding deriving the volume of an arbitrary pyramid.
"An arbitrary pyramid has a single cross-sectional shape whose lengths scale linearly with height. Therefore, the area of a cross section scales quadratically with height, decreasing from
at the base ([PLAIN]http://mathworld.wolfram.com/images/equations/Pyramid/Inline5.gif) to 0 at the apex (assumed to lie at a height [PLAIN]http://mathworld.wolfram.com/images/equations/Pyramid/Inline6.gif).
The area at a height http://mathworld.wolfram.com/images/equations/Pyramid/Inline7.gif above the base is therefore given by"
Can you describe this to me mathematically but easily?
The article seems quite clear, so unless you explain exactly which terms are giving a problem, it's difficult to answer.
It might be easier if you think downwards from the apex. The width of the pyramid in any direction at a given level is then proportional to how far down you've gone, so the area at a given level is proportion to the square of how far down you've gone. The area at the bottom sets the constant of proportionality.
Why does the area at any given level proportionate to the square of the height? Why does the (h-z)^2 get divided by the h^2
If something is twice as wide in both directions, it has four times the area. In general, for different sizes of the same shape, the area is proportional to the square of the size.
If ##k## is the constant of proportionality we have the following at any given level ##z## which is a distance ##(h-z)## down from the apex:
$$ A(z) = k \, (h-z)^2 $$
At the base, the area is equal to the base area ##A_b## and ##z = 0##, so we have
$$ A_b = k \, h^2 $$
By simple algebra, that means ## k = A_b / h^2 ##, giving the general rule:
$$ A(z) = A_b \frac{(h-z)^2}{h^2} $$
By saying $$ A(z) = k \, (h-z)^2 $$, why do you have $$ (h-z)^2 $$, I would understand if it was a square based pyramid (area = s^2), but the article refers to any arbitrary pyramid (say, pentagonal base).
For any flat shape, if the size is increased by some factor in all directions, the total area increases by the square of that size. More generally, if the size is increased proportionally in any direction, lengths in that direction and the total area are both multiplied by the same amount, so if the size is increased in two different directions by the same amount (as occurs in this case) lengths are multiplied by that amount and then by the same amount again, giving the square of the original amount.
(If you find it helps your understanding, imagine that the shape is full of tiny squares, each of which will scale up in the same way).
I see, is there some mathematical law that defines this, or is this just intuition?
It's very basic standard mathematics, just involving the concept of multiplication and the definition of area. The area of a rectangle is given by its length times its width, so if the length is multiplied by some constant and the width by another constant then the area is multiplied by the product of the two constants. If the two constants are the same, the area is multiplied by the square of the constant. The area of any flat shape can be approximated as closely as you like by a set of rectangles, so the same rule also applies to the shape as a whole.
Edit: The bit about "flat shape" is true in any case you'll encounter normally anyway, but just in case any mathematical nerds are watching I'll mention that mathematicians have some weird stuff such as "space-filling curves" that don't follow the conventional rules.
  • · Replies 47 ·
9K
