Calculating young's modulus from data provided
Young's modulus for Polyester Polyurethane can be estimated using the provided tensile strength and modulus values. The 100% modulus is 1500 psi, while the 300% modulus is 2950 psi, indicating that the material transitions into a plastic region beyond 100% extension. Young's modulus is defined as the slope of the stress vs. strain curve in the elastic region, and for this material, it is suggested to be around 150,000 psi. The discussion highlights the challenges in determining Young's modulus for materials with significant plastic behavior. Understanding these properties is crucial for applications involving this film material.
flyingbird
I am using one film mateial (Polyester Polyurethane) for some purpose. I have got data sheet from the manufacturer with following details:
Durometer 90Shore A D 2240
Specific Gravity 1.19 D792
Elongation @ Break Elast 515% D 412
Tensile Str. @ Break Elast 5,400 psi D 412
100% modulus 1500 psi D 412
300% modulus 2950 psi D 412
Here D... is the ASTM test method. I have to determine Young modulus for this material, I don't have details of ASTM test method. I have uploaded PDF file of material spec too.
Can anyone help me here?
44 views so far and no reply! :(
What is your definition of Young's Modulus?
The information is right there in your list : What do you think the 100% & 300% Moduli are?
Young modulus is slop of the stress vs strain curve in elastic region. The values which are given here as 100% & 500% moduli cannot be young modulus, because tensile strength is 5400psi which is generally much less than young modulus. Young modulus for this material should be around 150000 psi!
You are looking at a plastic material.
This means that in a test to destruction it has a very small elastic region and a large plastic region.
YoungsModulus = stress\,x\,\frac{1}{{strain}} = stress\,x\,\frac{{{L_0}}}{{\Delta L}}
So at 100% extension
stress\,x\,\frac{{{L_0}}}{{2{L_0} - {L_0}}} = \frac{{stress}}{1} = 1500psi
and at 300%extension
stress\,x\,\frac{{{L_0}}}{{4{L_0} - {L_0}}} = \frac{{stress}}{3} = \frac{{2950}}{3} = 283psi
The fact that these two figures are different tell us that by the time you have drawn the material out to 300% extension you are well into the plastic region and require little extra force to achieve this. If you pulled the film out the 300% extension and let go it would remain well stretched.
It is true that you cannot be absolututely certain that the material is elastic up to 100% extension, from the figures given, but they are standard marker points on the curve.
Oops.
I got the point, thanks a lot. :smile:
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
56K
