Calculation for Asteroid Orbital Period
5 replies · 15K views · last reply
Saladsamurai
Of an asteroid whose Mass is 2.0*10^-2 times that of Earth's and whose distance from the sun is twice the Earth's distance from the sun. Find the period in years.
I am supposed to use the concept of gravitational F=centripetal force[tex]=m\frac{v^2}{r}[/tex] and the fact that [tex]v=\frac{2\pi r}{T}[/tex]
so this is my attempt:
[tex]F_g=\frac{GMm}{r^2}=m(\frac{v^2}{r})[/tex]
implies [tex]\frac{GMm}{r^2}=\frac{m4\pi^2r}{T^2}[/tex]
implies[tex]T=\sqrt \frac{4\pi^2r^3}{GM}[/tex]
This M though is the mass of the sun correct?
Casey
Maybe just the acting of posting it helps, cause I got this one too. 2.8 years.
Thanks,
Casey
Yes, M is the mass of the sun and m is the asteroid in this case.
Thanks,
Casey
Glad to hear it!:smile:
Properly speaking, you will probably learn in your course about Newton's generalization of Kepler's Third Law, in which case M is actually the total mass of the "system". But since the asteroid's mass is negligibly small compared to the Sun's, you get entirely satisfactory precision using the Sun's mass alone. (You'd see a slight discrepancy if we used Jupiter as the second mass; for binary stars, you *must* use the sum of the stars' masses.)
You can avoid the annoyance of needing to know G and M (or even pi!) or even worrying about units by solving a comparison ratio. Both the Earth and this asteroid orbit the Sun, so we have
T^2 for asteroid 4(pi^2)(r for asteroid ^3)/GM
______________ = _________________________
T^2 for Earth 4(pi^2)(r for Earth ^3)/GM
(this doesn't show as neatly as I'd like and I don't have a TeX manual)
or just
(T for ast. / T for Earth)^2 = (r for ast. / r for Earth)^3 .
The asteroid orbits twice as far from the Sun as the Earth does, so
(T for ast. / T for Earth)^2 = 2^3 = 8 ;
thus the asteroid's orbital period is sqrt(8) times the Earth's (which is one year) or
about 2.83 years.
The comparison ratio approach is very tidy when the problem provides the right sorts of information. The only extent to which you even deal with units is in making sure that quantities to be compared in ratios are in the same units.
or just
about 2.83 years.
Nice one dynamicsolo. I like how you saw a proportion in this; I have a hard time seeing thise right off the bat. When I drew a diagram of this I had a feeling I could do something to this affect, but I have never been good at proportions.
I need to go ahead and find some more problem like this so I can learn how to spot ratios better.
I always like it when somebody reads through a post; sees that the OP has been answered and has the solution; and still takes the time to show the OP another way it could have been solved. PF rocks!:smile:
Thanks again,
Casey
