How to Calculate the Mass of Benzene at 15 Degrees Celsius?
  • Thread starter Thread starter MacLaddy
    Calculation Mass
To calculate the mass of benzene at 15 degrees Celsius, the density is given as 0.8787 g/mL. Converting the volume of 0.1500 L to mL results in 150.0 mL, allowing for direct multiplication with the density. The calculation yields a mass of 131.805 g. There was initial confusion regarding unit conversions, particularly how to handle g/mL and L, but clarification was provided on proper dimensional analysis. Ultimately, both methods of calculation lead to the same result, confirming the accuracy of the mass determination.
MacLaddy
The density of Benzene at 15 degrees Celsius is 0.8787 \frac{g}{mL} Calculate the mass of 0.1500 L of Benzene at this temperature.
Density=\frac{mass}{volume}
The part of this problem that is throwing me off is the g/mL, and L measurements. What is have done is I took the density and multiplied it by 1000 to get g/L instead of g/mL. The equation then looked like this.
878.7\frac{g}{L} = \frac{mass}{0.1500L}\rightarrow<br /> 878.7(0.1500)=mass\rightarrow<br /> 131.805g = mass
I'm not sure if I am correct with that result, but even if I am I believe I am making a mistake with how I distribute L and g/mL across my multiplication. Any advice on this problem would be appreciated.
Mac
You did OK. You could as well convert volume to mL (0.1500L = 150.0mL) - final result would be identical.
Thanks for the double-check, Borek.
I realized what was confusing me so badly. I knew that if I multiplied L by 1000 I could get mL, yet I was seeing that I also needed to multiply my g/mL by 1000 to get g/L. I was thinking, "how can I multiply both by 1000, shouldn't I be dividing one of the figures?" Anyhow, it finally dawned on me, it's g/mL, not just mL.
Thanks again.
Mac
MacLaddy said:
I knew that if I multiplied mL by 1000 I could get L
Quite the opposite - mL has to be divided by 1000 to be converted to L. Using dimensional analysis:
10\ \text{mL} = 10\ \text{mL}\frac{1\ \text{L}}{1000\ \text{mL}} = 0.01\ \text{L}
You're correct, Borek, and I misspoke. I was actually referring to multiplying L by 1000, as in your post here,
I've corrected the error in that post.
