Calculation of power for battery charging
The discussion focuses on calculating the power required to charge a 12V/50AH x 4 lead-acid battery for an electric scooter, comparing it to internal combustion scooters. The charger specifications indicate a 400W output, and the user estimates a need for 2.4 kWh to reach 90% charge in 6 hours. However, the efficiency of the charging process is highlighted as a critical factor, with estimates ranging from 34% to 86%, indicating significant energy losses during charging and transmission.
  • Understanding of lead-acid battery specifications and charging cycles
  • Familiarity with electrical power calculations (Watt, kWh)
  • Knowledge of battery charger efficiency metrics
  • Awareness of energy loss factors in electrical systems
  • Research lead-acid battery charging efficiency and best practices
  • Learn about measuring energy consumption during battery charging
  • Investigate the impact of transmission losses on overall energy efficiency
  • Explore tools for estimating CO2 emissions from electricity generation
Electric vehicle enthusiasts, battery engineers, environmental analysts, and anyone involved in optimizing battery charging processes and energy consumption assessments.
AP1
Hi - I am trying to calculate the power required to charge a battery in order to compare the energy requirements of an electric scooter versus an internal combustion scooter. The electrical scooter specifications state:
battery: 12V/50AH x 4
time to 90% charge: 4.5 - 6 hours
charger: 400W / 7A
Am I correct in assuming that to recharge a discharged battery to 90%, it would take 2.4 kWh (i.e. 400 W x 6 h)?
Thanks for any advice you can offer.
AP
I think when you recharge a battery it is only about 50% efficient. I think your calculation is right.
I always thought battery chargers were more efficient than that. In any case, your numbers give 135W for the battery and 400 for the charger, an efficiency of 34%.
When someone asks me a question that involves charging efficiency (such as evaluating an electric vehicle), I typically use something like 90%. But I don't really have any basis for that.
charger: 400W / 7A
AP
I guess we have to assume you are charging a lead acid battery.
Given that assumption, your assumption is not correct.
A good charger will have 2 stages:
1. Maximum current with a rising voltage
2. Maximum voltage with a descending current
So the charger will not be operating at the rated power and current over the full charge.
Without having a http://www.thinkgeek.com/gadgets/travelpower/7657/", you can estimate the power transferred to the battery by graphing the voltage and current about every 30 minutes.
Thanks for all of the replies. The problem I have is that I do not have the batteries and charger to actually measure the power demand during a recharge cycle. I am trying to estimate this so that I can calculate (again, an estimation) the equivalent CO2 emission of electricity generation versus the same for a gasoline engine. I already know the CO2 emissions per kWh for the local electricity supply and so need to estimate the kWh required to charge the e-scooter battery.
AP
Chargers might reach 86% efficient but the charging process is a similar figure and then there are losses in the vehicle particular if 3 phase AC motors are used.
You must not discharge a battery too much otherwise it won't last long. They has been a debate what the Ah means?? Real useful power without demaging the battery or a 'theoretical' figure if the battery was 100% discharged.
Then there are transmission losses from the power station of 7 - 10%..
Long chains involving energy conversions add up to large overall losses.
