Calculation of the running coupling
4 replies · 2K views · last reply
Trifis
The beta function is defined as:
[tex]\beta(\lambda)=M\frac{d}{dM}\lambda[/tex]
If we make the substitution [itex]t=ln(p/M)[/itex] the above equation becomes:
[tex]\beta(\lambda)=-\frac{d}{dt}\lambda[/tex]
Now if we use e.g. the QED beta function
[tex]\beta(e)=\frac{e^3}{12\pi^3}[/tex]
and for [itex]e(p=M)=e_0[/itex] the result is
[tex]e=\frac{e_0}{1+(3e_0/16\pi^2)log(p/M)}[/tex]
which is clearly false.
What am I missing?
I think there must be some mistake in your integration. I would compute
$$ \int_{e(p)}^{e(M)} \frac{ de}{e^3} = \int_p^M \frac{1}{12\pi^2} \frac{dM}{M}$$
to find
$$ e(p)^2 = \frac{ e(M)^2}{1 + \frac{e(M)^2}{6\pi^2} \ln \frac{M}{p}},$$
which seems to have the behavior we ordinarily associate with QED.
I've made some typing errors.
The integration after introducing the new variable [itex]t=\ln{(p/M)}[/itex] is:
[tex]\frac{de}{dt}=-\frac{e^3}{12\pi^2}[/tex]
[tex]\int_{e(p)}^{e(M)} \frac{ de}{e^3} = -\frac{1}{12\pi^2} \int_{\ln{(p/M)}}^0 dt[/tex]
which yields the final result
[tex]e(p)^2 = \frac{ e(M)^2}{1 + \frac{e(M)^2}{6\pi^2} \ln \frac{p}{M}}[/tex]
The only disagreement between the two results that I was referring to in my original post is the wrong sign in the denominator.
It took me a couple of tries to realize it, but the problem is in the bounds on your integral. We start with
$$ I = \int_{M'=p}^{M' = M} \frac{dM'}{M'},$$
so when you change variables to ##t= \ln p/M'##, then
$$ I = - \int_0^{\ln p/M} dt.$$
You are right, I was thinking about p as the integral variable, but it was M' instead. Thanks for clearing this out!
