Calculations for accelerating particles in a Cyclotron
sss1
mv^2/2, f=qB/2pim
For this question part d, KE=mv^2/2=q^2B^2r^2/2m (I rearranged B=mv/qr for v and subbed into mv^2/2). q^2b^2r^2/2m=2F_cyc^2r^2m(pi)^2
But when I subbed the values in I got 16.45MeV but the answer says 165keV instead. I'm not sure what went wrong?
What's a good explanation for part e also?
Physics exam question 5 on a charged particle in a magnetic field, with a cyclotron diagram showing a circular magnetic region with an electric field gap and an AC source.
Printed exam text reading Question 5 continued, parts d and e: d) cyclotron with radius 53 cm accelerating deuterons at 12 MHz, asking for kinetic energy on leaving; e) asks why final kinetic energy does not depend on accelerating field E.
I got the same answer as you. (Except I rounded mine to an appropriate number of significant figures!)
It looks like the official answer is wrong - probably because whoever did it used r =53mm instead of r=53cm.
As you probably know, ther rules here require you to show your own thoughts/attempt before guidance is offered.
Well if the e field is strong, it’ll only take a few cycles until the particle leaves? Whereas if if the e field is weak, it’ll take a long time to leave the cyclotron, so the KE is the same regardless?
You need to do better than that. What is an expression for the kinetic energy of the particle just before it exits? Is there an ##E## in it?
