Calculations involving different Dielectrics and Capacitors
The discussion revolves around a problem involving a capacitor's dielectric constant, specifically transitioning from an air-filled capacitor to one that can store a specified amount of energy at a given voltage. Participants are exploring the relationships between capacitance, energy, and dielectric materials.
  • Participants discuss the formulas related to capacitance and energy storage, questioning the validity of the original poster's calculations. There is a focus on the correct interpretation of energy units and the appropriate formulas to use.
Some participants have provided clarifications regarding the formulas needed to solve the problem, particularly emphasizing the relationship between energy, capacitance, and voltage. There is an ongoing exploration of the dielectric constant and its implications for the capacitor's design.
There is a noted confusion regarding the energy value (millijoules vs. microjoules) and the reference to Table 25-1, which lists dielectric constants for various materials. The original poster's understanding of the problem setup and the formulas used is under scrutiny.
as2528
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: Need dielectric constant for given capacitor
Given a 7.4 pF air-filled capacitor, you are asked to convert it to a capacitor that can store up to 7.4 mJ with a maximum potential difference of 652 V. Which dielectric in Table 25-1 should you use to fill the gap in the capacitor if you do not allow for a margin of error?
I did the following:
C=(k*e*A)/d and Q=C*V=>C=Q/V
So:
Q/V=(k*e*A)/d=>k=Q/V*d/(A*e)=>k=7.4*10^-6/652*7.4*10^-12=>k=8.7616*10^-20
The answer is 4.7, and uses the potential between capacitors formula. Why are the formulas I used wrong? It seems to me like it makes sense.
What does that mean? What is Table 25-1?
In addition to what @hutchphd said:
Is the energy really 7.4mJ (millijoules) or did you mean 7.4μJ (microjoules)?
What formula relates energy (not charge) stored to C and V?
Table 25-1 was a table showing a few dielectric constants along with the materials they corresponded to. I was supposed to get 4.7 from the question, which was the part I failed on. On the table it said Pyrex was corresponding to that kappa.
That was u=.5c*v^2. So I calculated with charge which causes the error?
And it was the microjoules.
as2528 said:
That was u=.5c*v^2.
That's the correct formula. But as far as I can see, you didn't use it.
The charge (Q) is not needed. Try this:
Step 1: With the dielectric present, U(energy stored) =7.4μJ when V =652V. Use the formula U=½CV² to find C (the required capaicitance with the dielectric in place).
Step 2: Note that without the dielectric, the capacitance is 7.4pF. Use this and your result from Step 1 to find the dielectric constant.
Steve4Physics said:
That's the correct formula. But as far as I can see, you didn't use it.The charge (Q) is not needed. Try this:
Thank you! This cleared it up for me.
  • · Replies 17 ·
