Calculations involving different Dielectrics and Capacitors
The discussion centers on calculating the dielectric constant for a capacitor using the formula C=(k*ε*A)/d and the relationship between energy stored and capacitance. The user initially miscalculated the dielectric constant for a 7.4 pF air-filled capacitor intended to store 7.4 μJ at 652 V. The correct approach involves using the energy formula U=½CV² to determine the required capacitance with the dielectric and then finding the dielectric constant based on the initial capacitance. The dielectric constant for Pyrex, as indicated in Table 25-1, is 4.7.
  • Understanding of capacitor fundamentals, including capacitance and dielectric materials.
  • Familiarity with the energy stored in capacitors using the formula U=½CV².
  • Knowledge of dielectric constants and their significance in capacitor design.
  • Ability to interpret and utilize tables of dielectric constants, such as Table 25-1.
  • Study the derivation and application of the formula U=½CV² in capacitor energy calculations.
  • Research dielectric materials and their corresponding dielectric constants from reliable sources.
  • Explore practical applications of capacitors in electronic circuits, focusing on energy storage.
  • Learn about the impact of different dielectrics on capacitor performance and efficiency.
Electrical engineers, physics students, and anyone involved in capacitor design or analysis will benefit from this discussion, particularly those focusing on energy storage and dielectric materials.
as2528
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: Need dielectric constant for given capacitor
Given a 7.4 pF air-filled capacitor, you are asked to convert it to a capacitor that can store up to 7.4 mJ with a maximum potential difference of 652 V. Which dielectric in Table 25-1 should you use to fill the gap in the capacitor if you do not allow for a margin of error?
I did the following:
C=(k*e*A)/d and Q=C*V=>C=Q/V
So:
Q/V=(k*e*A)/d=>k=Q/V*d/(A*e)=>k=7.4*10^-6/652*7.4*10^-12=>k=8.7616*10^-20
The answer is 4.7, and uses the potential between capacitors formula. Why are the formulas I used wrong? It seems to me like it makes sense.
What does that mean? What is Table 25-1?
In addition to what @hutchphd said:
Is the energy really 7.4mJ (millijoules) or did you mean 7.4μJ (microjoules)?
What formula relates energy (not charge) stored to C and V?
Table 25-1 was a table showing a few dielectric constants along with the materials they corresponded to. I was supposed to get 4.7 from the question, which was the part I failed on. On the table it said Pyrex was corresponding to that kappa.
That was u=.5c*v^2. So I calculated with charge which causes the error?
And it was the microjoules.
as2528 said:
That was u=.5c*v^2.
That's the correct formula. But as far as I can see, you didn't use it.
The charge (Q) is not needed. Try this:
Step 1: With the dielectric present, U(energy stored) =7.4μJ when V =652V. Use the formula U=½CV² to find C (the required capaicitance with the dielectric in place).
Step 2: Note that without the dielectric, the capacitance is 7.4pF. Use this and your result from Step 1 to find the dielectric constant.
Steve4Physics said:
That's the correct formula. But as far as I can see, you didn't use it.The charge (Q) is not needed. Try this:
Thank you! This cleared it up for me.
  • · Replies 17 ·
