Calculus 1 finding absolute max and min
The discussion revolves around calculating the absolute maximum and minimum values of the shuttle's acceleration during its liftoff phase. The velocity model provided is v(t)=0.001397167t^3−0.080965t^2+16.02t−0.39, and the derivative is v'(t)=0.004191201t^2-0.16193t+16.02. The student encountered complex solutions when applying the quadratic formula to find critical points, indicating no real solutions exist for v'(t) = 0. Consequently, the maximum and minimum values of v(t) should be determined by evaluating the endpoints of the interval from t = 0 to t = 79.2 seconds. The constant term was clarified to be 0.39, correcting a potential misunderstanding in the model.
Wm_Davies
A University of Rochester student decided to depart from Earth after his graduation to find work on Mars. Before building a shuttle, he conducted careful calculations. A model for the velocity of the shuttle, from liftoff at t = 0 s until the solid rocket boosters were jettisoned at t = 79.2 s, is given by
v(t)=0.001397167t3−0.080965t2+16.02t−039
(in feet per second). Using this model, estimate
the absolute maximum value
and absolute minimum value (I found this through using Wolfram Alpha I don't understand how I get it though which is a problem)
of the acceleration of the shuttle between liftoff and the jettisoning of the boosters.
I got the derivative to be
v'(t)= 0.004191201t2-0.16193t+16.02
I imagine that I would have to find the critical points of this to get the max and min
So I used the quadriatic formula but I am getting imaginary numbers when I do this so I am having trouble coming up with the absolute maximum and minimum any help would be appreciated.
I assume you're looking for the absolute maximum value of the velocity.
For v(t), why do you have 039 as the constant term? Is that 39 or is there a decimal point missing in it?
Your v'(t) looks about right, and I find also that the solutions to v'(t) = 0 are complex, meaning that there are no real solutions to v'(t) = 0. This means that v'(t) > 0 for all t or that v'(t) < 0 for all t (not likely).
Since there are no times for which v'(t) = 0, to find the maximum and minimum values of v(t), check the endpoints of your domain, which is implied in your problem description.
it is supposed to be 0.39 instead of 39. I will try that what you suggest.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
