Calculus- how to find half of max height
jtt
the question says " when did the rock reach half its maximum height?
a rock is thrown vertically upward from the surface of the moon at a velocity of 24m/sec and
reaches height of s= 24t-0.8t^2
i figured out when the rock reaches max point which is 15 seconds. i think when velocity = zero is when you can figure out the max height. i don't know about half of max height.
If you know when the rock reached its maximum height, you must know what that maximum height is. Okay, divide that maximum height by 2, set your formula for height equal to that and solve. There will be two answer to that quadratic equation- the time the rock passes that height on the way up and the time it passes it on the way down.
the time it takes to reach max height is 15 seconds and the height is 180 ft. based on how i tried to interpret the last reply this is what i got:
24-.8t^2=90
-90 -90
24t-.8t^2-90=0
is this correct?
Yes, you'll have that quadratic equation. You'll obtain two solutions for the time, the second one being the time after the rock is thrown when it is at half the maximum height and on the way down. (As a check, the two solutions for the time should be symmetrical about the time at which the rock is at maximum height.)
is the equation 24t-.8t^2-90=0 factorable or will i have to use the quadratic equation? i started out by dividing the whole equation by 2 and i got:
12t-.04t^2-45=0
i'm stuck and not sure where to go from here...
It won't factor nicely: the solutions are irrational numbers. So you will need the quadratic equation.
