Calculus of variations changing variables
- Thread starter bobred
- Start date
10 replies · 2K views
Discussion
- 14,880
Your work looks correct. Unless you do another variable transformation, you will not get rid of the 2.
- 29,869
- 21,725
I imagine that since you are trying to find stationary values of this integral, they are not affected by a constant multiple, so you can drop the factor. I think it should be -2, but that's a minor point.
- 22,832
- 14,880
PeroK said:I think it should be -2, but that's a minor point.
This would depend on the order of the integration limits (note that ##a## was the lower integration limit in ##x## but ##A## is the upper integration limit in ##u## - of course I am just making the arbitrary inference that ##a## corresponds to ##A## here ...).
- 29,869
- 21,725
Orodruin said:This would depend on the order of the integration limits (note that ##a## was the lower integration limit in ##x## but ##A## is the upper integration limit in ##u## - of course I am just making the arbitrary inference that ##a## corresponds to ##A## here ...).
Yes, didn't notice that.
bobred
- 170
- 0
Thanks guys.
I may have missed this in my notes PeroK but if we are trying to find stationary points of a functional constant multiples can be ignored?
James
James
- 22,832
- 14,880
bobred said:but if we are trying to find stationary points of a functional constant multiples can be ignored?
Yes, but there is nothing strange about this. It works this way for functions as well, if ##f(x)## has the stationary point ##x=2##, then so does ##2f(x)##.
bobred
- 170
- 0
Yes, thanks for the clarification.
James
James
Homework Helper
Dearly Missed
- 10,704
- 1,723
bobred said:Thanks guys.
James
Positive multiples can be ignored, but omitting negative multiples changes the direction of optimization.
- 22,832
- 14,880
Ray Vickson said:Positive multiples can be ignored, but omitting negative multiples changes the direction of optimization.
But it does not change the fact that the point is stationary. Just exchanges minima for maxima.
Homework Helper
Dearly Missed
- 10,704
- 1,723
Orodruin said:But it does not change the fact that the point is stationary. Just exchanges minima for maxima.
Of course, but that is another issue. It certainly changes the second-order tests, so that instead of looking to see if the Hessian is positive-definite, we look instead to see if it is negative-definite. However, when I taught this stuff I recommended that students just "memorize" the conditions for a minimum, then switch the sign of the objective if the problem was a maximization; that eliminates the need for a whole raft of special cases, etc.
Maximizing cylinder volume using calculus of variations
- CrosisBH
- · Replies 1 ·
- Calculus and Beyond Homework Help
- Replies
- 1
How Does Changing Variables Affect Integrals in Calculus?
- LCSphysicist
- · Replies 2 ·
- Replies
- 2
Changing Variables and the Limits of Integration using the Jacobian
- agnimusayoti
- · Replies 21 ·
- Replies
- 21
Derivation of Lagrangian in the calculus of variations
- Joggl
- · Replies 3 ·
- Replies
- 3
Calculus of Variations, Isoperimetric, given surface area max volume
- mishima
- · Replies 11 ·
- Replies
- 11
Calculus of Variations: interesting substitution
- member 428835
- · Replies 10 ·
- Replies
- 10
Solving Second Order Partial Derivative By Changing Variable
- Peter Alexander
- · Replies 5 ·
- Replies
- 5
Calculus of Variations: Minimizing Fuel Consumption w/ v(t)
- Hunter Bliss
- · Replies 3 ·
- Replies
- 3
Calculus of Variations; Maximum enclosed area problem.
- Aaron Curran
- · Replies 5 ·
- Replies
- 5
Undergrad Calculus of Variations on Kullback-Liebler Divergence
- Master1022
- · Replies 3 ·
- Calculus
- Replies
- 3
