Calculus Question: Sketching a Function by Hand
5 replies · 2K views
Pull and Twist
Hey all, I'm currently working a Calculus problem that requires me to sketch $$f(x)=(3x-1)/(x-1)^2$$ without using a calculator.
Part A: Requires that we find;
i. x-intercept:
$$f(0)=(3*0-1)/(0-1)^2=-1$$
So $$f(0)=-1$$
ii. y-intercept:
$$f(x)=0$$ therefore; $$3x-1=0$$ or $$x=1/3$$
So $$f(1/3)=0$$
iii. horizontal asymptote:
This is where I get stuck...
My initial thought is to use limits of x as it approaches $$\infty$$.
$$\lim_{{x}\to{\infty}}f(x)=(3x-1)/(x-1)^2$$
$$\lim_{{x}\to{\infty}}f(x)=(3x-1)/(x^2-2x+1)$$
$$\lim_{{x}\to{\infty}}f(x)=(3/x-1/x^2)/(1-2/x+1/x^2)$$
$$f(x)=(3/\infty-1/\infty^2)/(1-2/\infty+1/\infty^2)$$
$$f(x)=(0-0)/(1-0+0)=0$$
So the horizontal asymptote is at y=0 when we approach $$\infty$$??
Also, if I then take $$\lim_{{x}\to{-\infty}}$$ of the function I would also get 0??
iii. vertical asymptote:
$$(x-1)^2=0$$
$$x=1$$
So then the vertical asymptote is at $$x=1$$?
Part B: Find the intervals of increase and decrease, and the local and maximum and minimum values.
$$f'(x)=((x-1)^2(3)-(3x-1)(2(x-1)*(1)))/((x-1)^2)^2$$
$$f'(x)=((3(x-1)^2)-(2(3x-1)(x-1)))/(x-1)^3$$
$$f'(x)=(3x-3-6x+2)/(x-1)^3$$
$$f'(x)=(-3x-1)/(x-1)^3$$
So then we can solve for the Critical Points:
We know $$x\ne1 $$and $$-3x-1=0 \implies x=-1/3$$
If we then take $$f(-1/3)=(3x-1)/(x-1)^2$$ we get $$f(-1/3)=-9/8$$
So our intervals are $$(-\infty,-1/3),(-1/3,1),(1,\infty)$$
[table="width: 500, class: grid"]
[tr]
[td][/td]
[td]$$-3x-1$$[/td]
[td]$$x-1$$[/td]
[td]$$f'(x)$$[/td]
[/tr]
[tr]
[td]$$(-\infty,-1/3)$$[/td]
[td]$$+$$[/td]
[td]$$-$$[/td]
[td]decreasing[/td]
[/tr]
[tr]
[td]$$(-1/3,1)$$[/td]
[td]$$-$$[/td]
[td]$$-$$[/td]
[td]increasing[/td]
[/tr]
[tr]
[td]$$(1,\infty)$$[/td]
[td]$$-$$[/td]
[td]$$+$$[/td]
[td]decreasing[/td]
[/tr]
[/table]
Based on the table, we can tell which intervals are increasing and decreasing and that the local minimum is $$f(-1/3)=-9/8$$ and since we have a vertical asymptote at 1, there is no local max.
Part C: Find the intervals of concavity, and the inflection points of $$f$$.
$$f''(x)=(((x-1)^3)(-3)-(-3x-1)(3(x-1)^2*(1)))/((x-1)^3)^2$$
$$f''(x)=((-3(x-1)^3)-3(x-1)^2(-3x-1)/(x-1)^6$$
$$f''(x)=(-3(x-1)^2((x-1)+(-3x-1)))/(x-1)^6$$
$$f''(x)=(-3(-2x-2))/(x-1)^4$$
$$f''(x)=(6(x+1))/(x-1)^4$$
We know $$x\ne1 $$and $$x+1=0 \implies x=-1$$
If we then take $$f(-1)=(3x-1)/(x-1)^2$$ we get $$f(-1)=-1$$
So our intervals are $$(-\infty,-1),(-1,1),(1,\infty)$$
[tr]
[td][/td]
[td]$$x+1$$[/td]
[td]$$x-1$$[/td]
[td]$$f''(x)$$[/td]
[/tr]
[tr]
[td]$$(-\infty,-1)$$[/td]
[td]$$-$$[/td]
[td]$$-$$[/td]
[td]concave up[/td]
[/tr]
[tr]
[td]$$(-1,1)$$[/td]
[td]$$+$$[/td]
[td]$$-$$[/td]
[td]concave down[/td]
[/tr]
[tr]
[td]$$+$$[/td]
[td]$$+$$[/td]
[td]concave up[/td]
[/tr]
[/table]
Based on the table, we can tell the concavity of the intervals and that an inflection point exists at $$f(-1)=-1$$ and since we have a vertical asymptote at 1, there is no inflection at 1.
Part D: Combine all the information from Part A-C and sketch the function.
I am currently working on this part and will post it once I am done.
Will someone let me know if I approaching this correctly?? Thank you.
Hi PullandTwist,
You're doing a great job here in finding for the horizontal asymptote for the given rational function and yes, the horizontal asymptote for this problem is at $y=0$. (Yes)
$$(x-1)^2=0$$
$$x=1$$
Correct. Vertical asymptotes are vertical lines which correspond to the zeros of the denominator of a rational function and in our case, $x=1$ is the zero of $(x-1)^2$.
PullandTwist
Part B: Find the intervals of increase and decrease, and the local and maximum and minimum values.[TABLE="class: grid, width: 500"]
[TR]
[TD][/TD]
[TD]$$-3x-1$$[/TD]
[TD]$$x-1$$[/TD]
[TD]$$f'(x)$$[/TD]
[/TR]
[TR]
[TD]$$(-\infty,-1/3)$$[/TD]
[TD]$$+$$[/TD]
[TD]$$-$$[/TD]
[TD]decreasing[/TD]
[/TR]
[TR]
[TD]$$(-1/3,1)$$[/TD]
[TD]$$-$$[/TD]
[TD]$$-$$[/TD]
[TD]increasing[/TD]
[/TR]
[TR]
[TD]$$(1,\infty)$$[/TD]
[TD]$$-$$[/TD]
[TD]$$+$$[/TD]
[TD]decreasing[/TD]
[/TR]
[/TABLE]
Your answers are all correct for this part as well.
Part C: Find the intervals of concavity, and the inflection points of $$f$$.[TABLE="class: grid, width: 500"]
[TR]
[TD][/TD]
[TD]$$x+1$$[/TD]
[TD]$$x-1$$[/TD]
[TD]$$f''(x)$$[/TD]
[/TR]
[TR]
[TD]$$(-\infty,-1)$$[/TD]
[TD]$$-$$[/TD]
[TD]$$-$$[/TD]
[TD]concave up[/TD]
[/TR]
[TR]
[TD]$$(-1,\color{red}{-1}\color{black})$$[/TD]
[TD]$$+$$[/TD]
[TD]$$-$$[/TD]
[TD]concave down[/TD]
[/TR]
[TR]
[TD]$$+$$[/TD]
[TD]$$+$$[/TD]
[TD]concave up[/TD]
[/TR]
[/TABLE]
Note that you missed out the negative sign on the y-value for the inflection point $(-1,\,-1)$.
I say $(-1,-1)$ is the inflection point since an inflection point is where a curve changes from concave upward to concave downward or vice verse, which you have already proved so.
I just realized I calculated my concavity incorrectly. This corrected table should reflect the proper results. I forgot that the denominator was being raised to the power of 4, thus making any negative x value positive.
[tr]
[td][/td]
[td]$$x+1$$[/td]
[td]$$(x-1)^4$$[/td]
[td]$$f''(x)$$[/td]
[/tr]
[tr]
[td]$$-$$[/td]
[td]$$+$$[/td]
[/tr]
[tr]
[td]$$(-1,1)$$[/td]
[td]$$+$$[/td]
[td]$$+$$[/td]
[td]concave up[/td]
[/tr]
[tr]
[td]$$+$$[/td]
[td]$$+$$[/td]
[td]concave up[/td]
[/tr]
[/table]
anemone said:
Hi PullandTwist,
That was actually meant to signify the interval I was checking for concavity, so it should be (-1,1) based on the critical points I used. I determined the inflection based on where the signs changed in the table, which gave me x=-1 and x=1, but since I already new that we have a vertical asymptote at 1, the inflection at 1 could be ignored.
See image below...
[TR]
[TD][/TD]
[TD]$$x+1$$[/TD]
[TD]$$(x-1)^4$$[/TD]
[TD]$$f''(x)$$[/TD]
[/TR]
[TR]
[TD]$$-$$[/TD]
[TD]$$+$$[/TD]
[/TR]
[TR]
[TD]$$(-1,1)$$[/TD]
[TD]$$+$$[/TD]
[TD]$$+$$[/TD]
[TD]concave up[/TD]
[/TR]
[TR]
[TD]$$+$$[/TD]
[TD]$$+$$[/TD]
[TD]concave up[/TD]
[/TR]
[/TABLE]
Ah, sorry about not checking out properly the signs that you got in the intervals that you set in. I worked this problem out on my paper and I noticed that $(-1,\,-1)$ is a valid inflection point.
Okay, by setting the second derivative equals 0 gives us $x=-1$ and substituting this back to the original rational function to get the corresponding $f(x)$ value, we see that this yields $f(-1)=-1$. So, $(-1,\,-1)$ may or may not be an inflection point.
Since inflection points are where the function changes concavity and since we have gotten only one critical point with its $x$-coordinate as $-1$, we only have two intervals to check: $(-\infty,-1]$ and $[-1,\infty)$.
Now, according to the table with the corrected result, it shows that the curve does change from concave downward to concave upward at $(-1,\,-1)$, hence, $(-1,\,-1)$ is an inflection point.
After all that, this is the graph I was able to get...
Oh, and I also reversed my x & y intercepts in my original post. Ooops... (Mmm)
