Can a car engine dipstick be magnetized
  • Context: High School
  • Thread starter Thread starter sgvaibhav
    Car Engine
The discussion revolves around the possibility of magnetizing a car engine dipstick and alternative methods for retrieving small metal objects from hard-to-reach areas, such as an A/C vent. Participants explore practical solutions and tools for this problem, including the use of neodymium magnets and specialized retrieval tools.
  • Experimental/applied
  • Some participants inquire about the feasibility of permanently magnetizing a dipstick to lift small metal objects.
  • Others suggest using a neodymium magnet attached to the dipstick as a fishing tool, emphasizing the need for secure attachment to avoid losing the magnet.
  • One participant mentions the effectiveness of a telescoping magnet tool for retrieving dropped items, sharing personal experiences with its use.
  • Another participant expresses difficulty in finding such tools locally and considers searching online for alternatives.
  • Some participants share their experiences with similar tools, noting their utility in retrieving small objects from tight spaces.
  • A participant mentions the uncertainty regarding the reliability of DIY tools they have created for this purpose.
Participants generally agree on the utility of using magnets for retrieval but express differing opinions on the practicality and effectiveness of magnetizing a dipstick versus using specialized tools. The discussion remains unresolved regarding the best approach to retrieve objects from the A/C vent.
Participants highlight limitations in local availability of tools and the potential challenges of securely attaching magnets to a dipstick. There is also uncertainty regarding the effectiveness of DIY solutions compared to commercial tools.
Individuals interested in automotive repair, DIY enthusiasts, and those facing similar challenges in retrieving small objects from confined spaces may find this discussion relevant.
sgvaibhav
Hi,
Is it possible to permanently magnetize a car engine dipstick?
If yes, what would be the easiest way to get it magnetized, such that it will be able to lift an (rusted steel) object which is about 10 grams or lighter.
Two ways , either you want the dipstick to attract the small metal pieces that sometimes get into the oil due to wear , although this is usually done by the oil filter , or you have dropped something into the lower part of the engine.
In the second case or all other cases that could be the case for you i would recommend getting a tool which is long and you can bend the stick and it has a pretty powerful neodymium magnet at it's end. it is designed for these cases when you drop something made from metal into an area into which you cannot get by hand.
i have used it several times , worked great.And they don't cost much.
Trying to magnetize a dipstick would not be that easy and the effect you would get would be a small one , I think not big enough to lift something.
Actually I had dropped some object inside my a/c vent / duct.
I carried out some dis-assembly to remove the grille, however I need something, which is very thin, and long, something like a dipstick to put inside the ducts, and to fish out the object using magnetic force.
Or what about attaching one or two neodymium magnets on each side of the dipstick, to use the dipstick as a fishing tool. Some tape can be applied to ensure that the magnet does not get lost in the ducts, and remains attached to the dipstick.
yes you could also do the way you described , but you have to make perfectly sure that the magnets are tied very strongly to the stick you will hold in your hand , otherwise you might end up with the magnets sticking to the metal plate of the oil reservoir and then the only way getting them out would be to dismantle the whole thing.
So what else can I say be careful.
Any chain auto parts store will have a magnet on a telescoping rod for a few bucks.
Sadly, I cannot find such a rod/stick over here in my country.
Just remembered, there are some hopes to find magnetic stick in ace hardware. Time to check it out there.
The Internet is a wonderful thing. It is a million times better than the Mail Order Catalogue of the past. Search Ebay?
Sound like you need something like this...
http://www.tooltopia.com/ullman-devices-14x.aspx?utm_source=googlebase&utm_medium=cse&utm_term=ULL14X&utm_campaign=googlebase_18u&gclid=CJy70NXDlLgCFcGe4Aodaz8ARQ
I'm a mechanic. I use this tool multiple times a day. It works great for retrieving nuts, bolts, etc. Not strong enough for anything heavier then a medium screwdriver. The shaft stays in whatever shape you bend it to. The magnet on the end is probably 7 or 8 mm in diameter.
yup this is an extremely good tool , once i dismantled an old carburetor from a good engine an some small screws fell into the intake manifold , this tool helped me a lot.
The OP should really get his hands on one of these.
I built some self made creative tools, which i will try digging inside to fish objects.
Dont know how reliable they are or how good they will work...
If my own DIY tools don't work, then this magnetic flux tool looks like my next option.
  • · Replies 16 ·
  • · Replies 42 ·
